May 26, 2012, 02:04:57 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Mach 3 in small Netbooks (1024 x 600)
Pages: 1   Go Down
Print
Author Topic: Mach 3 in small Netbooks (1024 x 600)  (Read 1089 times)
Valen
Active Member
Offline Offline
View Profile
« on: May 08, 2010, 01:41:44 PM »
I am trying to use Mach 3 in a small Toshiba NB 100 Netbook (10' screen).
(I have the smoothstepper hardware in order to use the USB port, because this computer has not a parallel port, of course...)
The problem is that its max screen resolution is 1024X600 pixels, and the standard Mach 3 screen needs 768 pixels of height..... and for that, some buttons are always out of the screen, and there is not any slice bar to move the Mach 3 screen up and down...! (I think it is a big bug or forgotten functionality in this software....!!!!!!)
Somebody have screens for only 600 pixels of height?
Valentin
 Undecided Undecided Undecided
« Last Edit: May 08, 2010, 01:51:59 PM by Valen » Logged
zealous
Active Member
Offline Offline
View Profile WWW
« Reply #1 on: May 15, 2010, 02:55:37 PM »
Selecting the "auto screen enlarge" in the "gen config" should fit the screen to your resolution.
Regards, Jason Blake
www.Fusioncnc.com
Valen
Active Member
Offline Offline
View Profile
« Reply #2 on: May 15, 2010, 04:18:45 PM »
Thanks....! It worked perfectly....!
 Wink Wink Wink Wink
Pages: 1   Go Up
Print
Jump to:
