Hello
Guest
it is
June 11, 2026, 03:18:11 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Initial setup - spindle PWM ok, axis PWM not ??
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Initial setup - spindle PWM ok, axis PWM not ?? (Read 18681 times)
Carnoustie, Scotland
Re: Initial setup - spindle PWM ok, axis PWM not ??
Reply #10 on:
October 05, 2010, 02:19:00 PM »
Do you have the correct port address?
You dont have a port assigned for the spindle step, you have pin 7 but port 0, maybe that is the issue.
Sweep
150
Reply #11 on:
October 05, 2010, 03:03:10 PM »
Hi Hood,
I probably unticked (unchecked) the spindle speed box as I thought I would concentrate on the XYZ and try solve one problem at a time.
The port address is 0x378 for port 1, and 0xdff0 for port 2.
...Sweep
Reply #12 on:
October 05, 2010, 03:07:35 PM »
Seems to be working fine here when I scope the outputs of the computers port, the only thing I see is you had Jog control switched off so you would not get any jogging.
Sweep
150
Reply #13 on:
October 05, 2010, 03:11:49 PM »
Do you get a nice square wave and what are your v/div and timebase settings?
thanks ...Sweep
Reply #14 on:
October 05, 2010, 03:59:19 PM »
No dont really get a square pulse but that is down to the scope more than anything , its a USB one. My real scope is at the workshop.
Heres a screenshot at full rapid jog.
Sweep
150
Reply #15 on:
October 08, 2010, 01:04:14 PM »
Sorry for wasting everyones time, but I seem to have a bit of an issue on my homemade circuit board ...forgot to take all my transitors back to ground
Reply #16 on:
October 08, 2010, 01:27:25 PM »
Just happy you found the issue and time wasnt wasted as if you hadnt posted you wouldnt have looked there, or at least it may have been longer before you did.
Print
Pages:
1
2
Go Up
« previous
next »
