May 26, 2012, 01:39:12 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Z-axis Auto zero wiring
Pages: « 1 2 3 4 5   Go Down
Print
Author Topic: Z-axis Auto zero wiring  (Read 2782 times)
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #40 on: April 08, 2011, 06:19:59 PM »
How can I test for noise?
I am using an alligator clip on the cutter and an insulated plate.
I'm assuming that you have to answer the questions before it starts moving. The fact that it moves up 1", tell me that the macro is running correctly, as it's supposed to move up 1" after hitting the plate. So as I said yesterday, I think noise is triggering it.
Disconnect the wire with the clip from the breakout board, and replace it with a short wire, about 2" long.
Touching the wire to ground, should light the digitize LED. If it does, run the macro.
Touch the wire to ground to stop it. If this works, you have noise.
cvk31
Active Member
Offline Offline
View Profile
« Reply #41 on: April 08, 2011, 07:39:45 PM »
Cool, Thank you so much.  I tried this and it worked so I popped a cap in its ***.
Now it works as seen on TV!
This is my first experience with electronics this sensitive. I really appreciate the help guys!
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #42 on: April 08, 2011, 07:51:30 PM »
Cool, Thank you so much.  I tried this and it worked ............
Good thing it worked, 'cause I was throwing in the towel. Smiley
Pages: « 1 2 3 4 5   Go Up
Print
Jump to:
