Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 26, 2012, 01:22:50 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
Mach Screens
Works in progress
Flash RU Screen
Pages:
1
2
3
4
5
6
7
Go Down
« previous
next »
Author
Topic: Flash RU Screen (Read 6036 times)
elpablito
Active Member
Offline
Re: Flash RU Screen
Reply #10 on:
May 03, 2010, 06:25:58 PM »
Hi Fabrice, thanks for testing.
Youre right I have that C:\ setting hard coded. I will correct that and repost in this forum
Regards
elpablito
Active Member
Offline
Re: Flash RU Screen
Reply #11 on:
May 04, 2010, 11:17:00 PM »
V1.31
This version corrects the problem of the C: being hardcoded.
I added drive selection capability. When you close mach, the last path used is remembered so you dont have to browse for your code folder everytime.
Also added the version textbox at the bottom right corner of the load screen.
Please report any bug you may found and I will correct them asap.
Last Edit: May 04, 2010, 11:31:26 PM by elpablito
elpablito
Active Member
Offline
Re: Flash RU Screen
Reply #12 on:
May 04, 2010, 11:52:19 PM »
This is V1.31
RU.swf
Fab6657
Active Member
Offline
Re: Flash RU Screen
Reply #13 on:
May 05, 2010, 02:26:56 PM »
Good evening,
i downloaded the last version. The selection of file thru more drives run well, thanks.
Now i can load a file but the screen are not generated, and can also not running the simulation.
The gcode listing is display ! Button MDI doesn't work too !
I place here a new screenshot.
Fabrice
elpablito
Active Member
Offline
Re: Flash RU Screen
Reply #14 on:
May 05, 2010, 04:51:55 PM »
Hi Fabrice,
I have intentionally disabled the MDI button because that screen is not yet finished.
I will look into your problem to see if I can reproduce it here. I think it may be related to mach configuration.
elpablito
Active Member
Offline
Re: Flash RU Screen
Reply #15 on:
May 05, 2010, 06:44:40 PM »
Fabrice,
For some reason mach is not loading your gcode file. If you check at your screen captures where the file name should be it reads "No File Loaded"
The code is loaded by flash independant of mach, thats why you can see it, but you cant run it because mach did not load anything.
Check if the same happens with the sample code files that come with mach like Scorpion or roadrunner.
When in the load screen, when you press on a file you should see the toolpath preview.
Also please send me the gcode file you are trying to load so i can use it to correct the bug
Regards
Pablo
elpablito
Active Member
Offline
Re: Flash RU Screen
Reply #16 on:
May 05, 2010, 08:33:33 PM »
In order to view the screen properly, please download and install this fonts into your system.
Fonts.rar
(83.04 KB - downloaded 90 times.)
Fab6657
Active Member
Offline
Re: Flash RU Screen
Reply #17 on:
May 06, 2010, 12:54:19 PM »
Hello,
so i test a little, with the right font, it is better.
But i still have problems with run.
Run doesnt start immediatly. I think i have errors but
i no see that displayed. I need to push many time the run button
for a correct start of the sequenz.
best regards,
elpablito
Active Member
Offline
Re: Flash RU Screen
Reply #18 on:
May 06, 2010, 01:27:20 PM »
Hi Fabrice,
Some buttons, as the Start button, that when unintentionally pressed may lead to a crash or accident, are protected by a safety timer.
You have to keep the button pressed for the specified time. If you release it before, the event will not trigger.
The default time value for the Start button is 500ms , and when in step mode 200ms.
You can change that to the value you preffer in the RUCONFIG.INI file.
regards
PD: The screen aspect is designed for 1280x1024 screen resolution
Last Edit: May 06, 2010, 01:30:16 PM by elpablito
elpablito
Active Member
Offline
Re: Flash RU Screen
Reply #19 on:
May 06, 2010, 01:30:40 PM »
Quote from: elpablito on May 06, 2010, 01:27:20 PM
Hi Fabrice,
regards
PD: The screen aspect is designed for 1280x1024 resolution
Pages:
1
2
3
4
5
6
7
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
