Hello Guest it is June 09, 2026, 09:09:10 AM
Author Topic: Flash RU Screen  (Read 148789 times)
Re: Flash RU Screen
« Reply #10 on: May 03, 2010, 06:25:58 PM »
Hi Fabrice, thanks for testing.
Youre right I have that C:\ setting hard coded. I will correct that and repost in this forum
Regards
Re: Flash RU Screen
« Reply #11 on: May 04, 2010, 11:17:00 PM »
V1.31
This version corrects the problem of the C: being hardcoded.
I added drive selection capability. When you close mach, the last path used is remembered so you dont have to browse for your code folder everytime.
Also added the version textbox at the bottom right corner of the load screen.
Please report any bug you may found and I will correct them asap.
« Last Edit: May 04, 2010, 11:31:26 PM by elpablito »
Re: Flash RU Screen
« Reply #12 on: May 04, 2010, 11:52:19 PM »
This is V1.31
Re: Flash RU Screen
« Reply #13 on: May 05, 2010, 02:26:56 PM »
Good evening,
i downloaded the last version. The selection of file thru more drives run well, thanks.
Now i can load a file but the screen are not generated, and can also not running the simulation.
The gcode listing is display ! Button MDI doesn't work too !
I place here a new screenshot.
Fabrice
Re: Flash RU Screen
« Reply #14 on: May 05, 2010, 04:51:55 PM »
Hi Fabrice,
I have intentionally disabled the MDI button because that screen is not yet finished.
I will look into your problem to see if I can reproduce it here. I think it may be related to mach configuration.
Re: Flash RU Screen
« Reply #15 on: May 05, 2010, 06:44:40 PM »
Fabrice,
For some reason mach is not loading your gcode file. If you check at your screen captures where the file name should be it reads "No File Loaded"
The code is loaded by flash independant of mach, thats why you can see it, but you cant run it because mach did not load anything.
Check if the same happens with the sample code files that come with mach like Scorpion or roadrunner.
When in the load screen, when you press on a file you should see the toolpath preview.
Also please send me the gcode file you are trying to load so i can use it to correct the bug
Regards
Pablo
Re: Flash RU Screen
« Reply #16 on: May 05, 2010, 08:33:33 PM »
In order to view the screen properly, please download and install this fonts into your system.
Re: Flash RU Screen
« Reply #17 on: May 06, 2010, 12:54:19 PM »
Hello,
so i test a little, with the right font, it is better.
But i still have problems with run.
Run doesnt start immediatly. I think i have errors but
i no see that displayed. I need to push many time the run button
for a correct start of the sequenz.
best regards,
Re: Flash RU Screen
« Reply #18 on: May 06, 2010, 01:27:20 PM »
Hi Fabrice,
Some buttons, as the Start button, that when unintentionally pressed may lead to a crash or accident, are protected by a safety timer.
You have to keep the button pressed for the specified time. If you release it before, the event will not trigger.
The default time value for the Start button is 500ms , and when in step mode 200ms.
You can change that to the value you preffer in the RUCONFIG.INI file.
regards
PD: The screen aspect is designed for 1280x1024 screen resolution
« Last Edit: May 06, 2010, 01:30:16 PM by elpablito »
Re: Flash RU Screen
« Reply #19 on: May 06, 2010, 01:30:40 PM »
Hi Fabrice,
regards
PD: The screen aspect is designed for 1280x1024 resolution
