Hello Guest it is June 09, 2026, 03:26:08 PM
Author Topic: New DSPMC Version 2  (Read 30063 times)
New DSPMC Version 2
« on: April 22, 2010, 11:58:36 PM »
Dear Mach3 Users,
We are pleased to announce the production release of DSPMC version 2 hardware.
Some of the key improvements:
8 Channels Servo Analog Outputs, Range ±10V, 16-Bit Resolution
8 Differential Quadrature Encoder Inputs. 32-Bit Resolution
8 Step and Direction Channels. Up to 2MHz Step Output Frequencies (Available soon with software upgrade).
8 Channels Analog Inputs, Range ±10Volts, 16-bit Resolution (7762M Only)
4 Mhz Encoder Input frequency. Encoder resolution multiplied by 4 thru Hardware
96 Digital I/O (64 Inputs & 32 Outputs)
For more information on DSPMCv2, please consult the user manual available at http://www.vitalsystem.com/dspmc
Thank you
VSI DSPMC Team
« Last Edit: January 25, 2011, 11:27:52 PM by vitalsystem »
Offline tomi
  •  11 11
DSPMCv2 Control Output Source Stepper in Mach3
« Reply #1 on: November 19, 2011, 11:34:36 AM »
Hi!
We try to use Stepper method for Controlling output source without any results. If I change Output Source to DAC and try to run test at least I get following error put nothing with Stepper mode.
Any ideas?
Dear Mach3 Users,
There is step and direction channels available soon and post is 2010 and I use latest Mach3 plugin.
Firmware version:
System: Rev: 7762 / 6.36, FPGA: 4710, ID: 16DD6
and downloaded firmware from vital systems:
Revision: 0629/7762
Wich one is newest?
Br.
 - tomi -
Re: New DSPMC Version 2
« Reply #2 on: November 19, 2011, 01:35:48 PM »
sorry the stepper outputs are not yet available.  we do want to add stepper outputs, but I dont know when it may happen.
We will be releasing a new board named HiCON with step/dir outputs.  Will let you know when it is released.
rgds
Rufi
« Last Edit: November 21, 2011, 10:17:20 AM by vitalsystem »
« Reply #3 on: November 30, 2011, 07:56:34 AM »
Will the HiCONN have analog outputs? Can you tell us the differences from the DSPMC board?
Maynard
