Hello Guest it is June 10, 2026, 11:38:32 PM
Author Topic: VB Scripting Basics  (Read 9397 times)
Offline Dom
  •  22 22
    • Bridgeport CNC Retrofit Blog
VB Scripting Basics
« on: April 14, 2010, 10:03:34 AM »
Please could someone help me with the code to make a button that only produces an action whilst the button is being pressed?
I have made custom buttons that will toggle, pressing once to turn on an output and a second time to turn off an output but what I really need a button that works like the jog buttons and will only enable an output whilst it is pressed and turns off the output the moment the button is released.
Re: VB Scripting Basics
« Reply #1 on: April 14, 2010, 11:51:22 AM »
Thats easy to do when making your screen in flash. Dont know if can be done with traditional screens
on (press) {
   fscommand ("VBMacro","Button down script");
on (release)`{
   fscommand ("VBMacro","Button release script");
What screen/screen designer are you using?
If you are not using a custom screen maybe you can modify the flash mach nation to fix your needs
Regards
Pablo
Offline Dom
  •  22 22
« Reply #2 on: April 14, 2010, 11:54:08 AM »
I'm using the standard mach3 screen, modified with a few extra buttons i've added using the reccomended machscreen screen designer program. I wouldnt know where to begin with flash!
« Reply #3 on: May 08, 2010, 08:27:56 PM »
You can set up a simple BRAIN that monitors the DO button AND
If it is ON then produce and action
IF it is OFF then cancell the action
Hope that helps
