Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 26, 2012, 12:45:22 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
4-th Axis running bad
Pages:
1
2
Go Down
« previous
next »
Author
Topic: 4-th Axis running bad (Read 994 times)
Greolt
Global Moderator
Offline
Re: 4-th Axis running bad
Reply #10 on:
August 28, 2010, 04:57:05 PM »
I don't expect it will have any effect when jogging,
Rather try entering G1 A360 Fxx via the MDI.
You should then see the compensation adjust according to a combination of the value in the "Rotation Radius" DRO and the Z axis DRO
Always within the constraints of the motor tuning settings.
You referred to "Rotation Diameter", do you run an older Mach version? This was fixed last year.
Note if you have a value of zero in the "Rotation Radius" DRO it will turn this feature off.
This is a bug. Brian is aware of it but we are still waiting for it to be fixed.
Greg
ludiheum
Active Member
Offline
Reply #11 on:
August 28, 2010, 05:41:22 PM »
Thanks Greg it worked now, i was just doing it wrong. Just another thing:
I made a code with rhinocam for testing the 4 axis, I just made a 30mm radius cylinder and a finishing operation, so its just basic, just a constant Z height, but rhinocam outputs lots of decimals, like 29.9994 and then 29.9998 so it goes like steps, becuase it has to move the Z and then rotate the A a bit, also its strange, cause the A axis goes to lets say 43.636 and then for the next that is 47.273, it just doesnt go the 4 degrees up(the short way), it takes the long way and spins more that it should, i dont know if it was that i made a bad code, dont you know where i can find a 4 axis test code ?
heres a piece of the code:
G00 G49 G40.1 G17 G80 G50 G90
G21
(4th Axis Roughing)
M6 T2
M03 S1
G01 X-4.4120 Z36.0000 A0.000 F19998.
Z29.9895 A0.000
Z29.9996 A-1.818
Z29.9974 A-5.455
Z29.9986 A-7.273
Z29.9997 A-10.909
Z29.9959 A-14.545
Z29.9998 A-16.364
Z29.9994 A-20.000
Z29.9993 A-25.455
Z29.9982 A-27.273
Z29.9999 A-30.909
Z29.9977 A-32.727
Z29.9998 A-36.364
Z29.9978 A-38.182
Z29.9995 A-41.818
Z29.9980 A-43.636
Z29.9999 A-47.273
Z29.9982 A-49.091
ludiheum
Active Member
Offline
Reply #12 on:
August 28, 2010, 05:45:22 PM »
I just have noticed that the problem of the extra spins may be the negative degrees, i just remove the - in a couple of lines and it went fine, i just dont know why that - are there
ludiheum
Active Member
Offline
Reply #13 on:
August 30, 2010, 02:02:50 PM »
And as for the 4 decimals that rhinocam outputs, i just went to postprocessors edit and changed there the number of decimals to 1, that fix it
Pages:
1
2
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
