Hello Guest it is June 10, 2026, 12:31:49 PM
Author Topic: Vinyl cutting.  (Read 32112 times)
  •  9,356 9,356
Vinyl cutting.
« on: April 05, 2010, 10:54:54 AM »
A short video of cutting sticky back plastic.
                       http://www.tweakie.byethost10.com/anelpako.wmv
« Last Edit: January 09, 2019, 04:02:16 AM by Tweakie.CNC »
Re: Vinyl cutting.
« Reply #1 on: April 06, 2010, 10:17:49 AM »
Excellent, as always, my friend, thanks for sharing  8)
  •  9,356 9,356
Re: Vinyl cutting.
« Reply #2 on: April 06, 2010, 11:42:38 AM »
Thank you Dave.
Truth be known, my buddy Terry makes a much better job of the music than I make of the video's !  :'(
Re: Vinyl cutting.
« Reply #3 on: April 06, 2010, 02:48:37 PM »
Yes, Terry's a talented person for sure. Being a bit of guitarist myself, I can appreciate what he's doing -  :)
.....and of course, that doesn't steal away from your obvious talent, so quite being so modest, it's guys like you that I look up to  ;)
Re: Vinyl cutting.
« Reply #4 on: April 06, 2010, 07:15:41 PM »
That's pretty neat, Tweakie. Thanks for sharing it with us.
  •  9,356 9,356
Re: Vinyl cutting.
« Reply #5 on: April 07, 2010, 02:05:07 AM »
Thanks Sam.
If it wasn’t for the encouragement from all you guys I think I would still be engraving Road Runner
There has been quite a lot of discussion about tangential control and it’s necessity for producing tight corners which is why I made this video to demonstrate that, as far as vinyl is concerned, the simple ‘drag knife’ method produces more than acceptable results.
Terry has a recording studio built in his house, he plays the bass, acoustic and electric guitar’s and sings the vocals but the rest is all electronically generated. The synth alone looks like the Star-ship Enterprise. He is a very talented fella and I am fortunate indeed to be able to use his music in my video’s.
Offline Arbo
  •  50 50
Re: Vinyl cutting.
« Reply #6 on: September 23, 2010, 09:20:27 PM »
Cool stuff.  I have seen where people have made adapters to put knives from cutters into their routers.  Been thinking about doing that.
Wonder about generating the gcode.  I imagine it's just set up like routing something out of wood or such, just with the blade rather than cutter...?
  •  9,356 9,356
Re: Vinyl cutting.
« Reply #7 on: September 24, 2010, 01:03:41 AM »
Arbo,
Any vector code works just fine.
When I built my cutter the Roland blades were very expensive but now the Chinese equivalent blade and holder is so cheap it is just a matter of building a spring loaded mount.  ;)
Offline Vogavt
  •  260 260
Re: Vinyl cutting.
« Reply #8 on: April 02, 2012, 09:50:12 PM »
Great video!
Could you point me to some sort of guide/pdf for making the spring loaded mount you're talking about? I suppose you have a link for where to find the inexpensvie Chinese blade holders too?
Thanks in advance,
Vogavt
  •  9,356 9,356
Re: Vinyl cutting.
« Reply #9 on: April 03, 2012, 01:27:46 AM »
Hi Vogavt,
Just a suggestion...
The Roland type blade holders and replacement blade are readily available on ebay.
A small ball bearing drawer runner / slide would be ideal - mount vertically to the Z axis, fit the blade holder to the moving part, use a self-tap screw as a bottom end stop and either a weight or spring to provide the contact pressure.
