May 26, 2012, 12:29:26 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  FAQs
| | |-+  Machine disoriented after line 9000
Pages: 1   Go Down
Print
Author Topic: Machine disoriented after line 9000  (Read 446 times)
Blacktable
Holding
Offline Offline
View Profile
« on: April 01, 2010, 11:41:28 AM »
I have a small CNC milling machine that I run with a laptop without any problem until Mach 3 start processing line 9.000 (approximatively). Does anybody know the reason for this, since I have been waisting a lot of time and material because of this problem.
N4NV
Active Member
Offline Offline
View Profile
« Reply #1 on: April 02, 2010, 11:23:24 PM »
Is it the 9000th line or line number 9000?  An unlicensed version of Mach is only good for 500 lines.  If your program is numbered every 20, i.e 20, 40 60 80 etc, then an unlicensed version of Mach would stop around line 9000.
Vince
Pages: 1   Go Up
Print
Jump to:
