May 26, 2012, 12:24:04 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Flash Screens
| | | |-+  My flash screenset with touch and wizards
Pages: « 1 2   Go Down
Print
Author Topic: My flash screenset with touch and wizards  (Read 2761 times)
elpablito
Active Member
Offline Offline
View Profile
« Reply #10 on: April 04, 2010, 10:42:54 PM »
I did some research about nesting and found that it requires to implement some algorithms that look pretty difficult, specially for actionscript.
1) Finding the centroid of each nested part
2) Find a No Fit polygon
3) Recursive genetic algorithm for the sorting sequence.
For the time I have now I dont think i can make it. Maybe i would try to write something in C# and invoke it from flash using fscommand.
In the meantime, I added a wizard list feature to the screenset so instead of running only one wizard generated code at a time, they can be added to a list an run all toghether.
They can also be deleted from the list, and when clicked they get you to the line of code where that particular wizard starts
The following image shows one surfacing operation followed by three circular pockets
Fab6657
Active Member
Offline Offline
View Profile
« Reply #11 on: April 04, 2010, 11:14:41 PM »
Hello Pablo,
you have right with point 3, some people dont use a fix point for the mesurement on the table with auto tool zero,
maybe also make an macro button ?
Fabrice
zealous
Active Member
Offline Offline
View Profile WWW
« Reply #12 on: April 09, 2010, 05:25:30 PM »
Great job, please post this in the "Work in progress" section as well.
Regards, Jason Blake
www.Fusioncnc.com
elpablito
Active Member
Offline Offline
View Profile
« Reply #13 on: April 09, 2010, 07:17:44 PM »
Thank you very much,
I currently removing hard coded parts to make it more customizable for other users.
I hope to make great progress this weeklend as far as my girlfriend doesnt kick my ass
Regards
hightechkey
Active Member
Offline Offline
View Profile
« Reply #14 on: April 22, 2010, 08:51:00 AM »
Dear Sir
Your flash screen is really great. Can I get this screen set. Thank...
High Tech Key
elpablito
Active Member
Offline Offline
View Profile
« Reply #15 on: April 22, 2010, 07:18:01 PM »
Thanks for your comments
Im doing some modifications so anyone can use it by customizing an external configuration.
I will make it available as soon as I this it is safe to use it
Regards
elpablito
Active Member
Offline Offline
View Profile
« Reply #16 on: April 25, 2010, 02:44:53 PM »
Im currently working on this
http://www.machsupport.com/forum/index.php/topic,14762.new.html
Please post your suggestions
elpablito
Active Member
Offline Offline
View Profile
« Reply #17 on: April 25, 2010, 10:16:17 PM »
For those interested, I have started a post to share the screen
http://www.machsupport.com/forum/index.php/topic,14765.0.html
regards
Pages: « 1 2   Go Up
Print
Jump to:
