May 26, 2012, 12:12:47 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Licencing a wizard
Pages: 1   Go Down
Print
Author Topic: Licencing a wizard  (Read 526 times)
arbus
Active Member
Offline Offline
View Profile WWW
« on: March 27, 2010, 09:38:15 AM »
How would you go about licensing a wizard for Mach?  Similar to the NFS wizards?
Is it possible to have a trial wizard which you could activate if it were purchased?
Anybody done this before?
Thanks for any replies...
Ron Ginger
V4 Screen Contributor
Offline Offline
View Profile WWW
« Reply #1 on: April 03, 2010, 05:32:52 PM »
Mach does not support a general way of licensing wizards. the newfangled ones are handled as a special case in the wizard open code.
For V4 Brian is looking at some changes that would let you use compiled VB code. With this your code would not be visible and you could handle any license scheme within the VB code.
Pages: 1   Go Up
Print
Jump to:
