Hello Guest it is June 12, 2026, 02:20:09 AM
Author Topic: Pokeys and spindle index  (Read 11026 times)
Offline N4NV
  •  398 398
« on: March 19, 2010, 03:26:01 PM »
Another question about Pokeys setup.  I have a hall effect sensor that is used to measure my spindle RPM.  It works great when connected to pin 13 of my BOB.  I connected it to pin 3 of my Pokeys and set that pin as a digital input.  I then set the spindle index as port 10 pin 3 of my ports and pins setup screen.  It does not read RPM in this configuration.  Am I doing something wrong?
Vince
Offline borisz
  •  220 220
    • www.poscope.com
Re: Pokeys and spindle index
« Reply #1 on: March 19, 2010, 04:24:33 PM »
USB and paralel ports are not working in same way.
To measure speed over USB, there should be some kind of counter implemented and sent value to Mach via plugin.
That is not implemented.
regards
Boris
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Offline N4NV
  •  398 398
« Reply #2 on: March 19, 2010, 06:34:47 PM »
Thanks, I will keep it on the BOB then.
Vince
