Hello Guest it is June 09, 2026, 08:06:59 PM
Author Topic: Pokeys and MPG  (Read 13481 times)
Offline N4NV
  •  398 398
Pokeys and MPG
« on: March 19, 2010, 11:16:20 AM »
I have an MPG wired up to my Pokeys pin 1 and 2.  I set up the MPG in port and pins to port 10.  It does not work.  It was working properly when connected directly to the BOB and set up for port 1.  In the Pokeys configuration screen I have pin 1 and 2 set up as encoder a and b.  In the Pokeys diagnostic screen, when I rotate the MPG, pins 1 and 2 blink.  What am I missing?  Also, is there a more thorough manual for using Pokeys with Mach than the help screens in the plug-in?
Thank you,
Vince
Offline N4NV
  •  398 398
Re: Pokeys and MPG
« Reply #1 on: March 19, 2010, 11:29:32 AM »
Thank you,
Vince
Update, I restarted the computer and the MPG is almost working.  Now, when I rotate the MPG 4 clicks, I get only one input to Mach, that is if I am set for .001" per step, I have to rotate the MPG 4 clicks to get the one step of .001"  There must be something simple I am missing.
Thanks again,
Vince
Offline N4NV
  •  398 398
Re: Pokeys and MPG
« Reply #2 on: March 19, 2010, 11:43:19 AM »
Thank you,
Vince
Thanks again,
Vince
I think I got it working correctly.  I changed the setting in the Pokeys setup to 4X sampling and it seems to work.  I am still looking for a more detailed manual for using Pokeys with Mach.
Vince
Offline borisz
  •  220 220
    • www.poscope.com
Re: Pokeys and MPG
« Reply #3 on: March 19, 2010, 12:57:30 PM »
Hi!
There should be an update avaiable soon which will greatly improve MPG functions.
regards
Boris
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
