Hello Guest it is June 12, 2026, 08:14:18 AM
Author Topic: pokeys vs DL06 PLC?  (Read 19940 times)
pokeys vs DL06 PLC?
« on: March 09, 2010, 06:32:36 PM »
I have been doing a retrofit for way longer than I would like to admit and purchased an Automation Direct DL06 and all the necessary breakout hardware for doing a lot of the i/o on a vertical machining center with a tool changer.  I am just now getting to the tool changer and was thinking about maybe using the pokeys for the i/o instead.  It seems like it might be easier to program it with a brain or macro rather than having the plc handle some of the i/o and the smoothstepper I am using handle the rest.
Any thoughts would be appreciated.
Bill
Offline borisz
  •  220 220
    • www.poscope.com
Re: pokeys vs DL06 PLC?
« Reply #1 on: March 09, 2010, 11:23:31 PM »
PoKeys works just fine with brains.
regards
Boris
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
« Reply #2 on: March 10, 2010, 03:23:31 AM »
Bill,
 Pokeys is a great wee device but I would say the PLC is the better option for a tool changer especially as you already have it. Main reason is your tool changer is very likely to be 24v and the PLC can interface directly to that (presuming its a DC or relay out PLC) , with the pokeys you would need to convert the 5v to 24v and vice versa.
The Pokeys is very nice for switch panels and hand held pendants and is a nice price when comparing to a PLC, especially if you want analogue Inputs.
Offline N4NV
  •  398 398
« Reply #3 on: March 10, 2010, 07:25:30 AM »
I used a PLC (Cubloc) to run my tool changer.  I found it much easier to program than using brains for control.
Vince
« Reply #4 on: March 10, 2010, 10:18:00 AM »
Thanks for all the input.  This might be wishful thinking, but I wonder if anyone has posted a program for a tool changer anywhere.  I haven't done ladder logic in forever.  I know I would have to edit it, but that always seems way easer than starting from scratch.
Best,
Bill
Offline N4NV
  •  398 398
« Reply #5 on: March 10, 2010, 12:12:07 PM »
This is getting off topic, but if you check out this thread I posted the code needed to run my tool turret.  I also posted some code for Mach to talk to the Cubloc.
http://www.cnczone.com/forums/showthread.php?t=50685&highlight=cubloc
It's a long thread so you may have to did to find the information.
Vince
« Reply #6 on: March 10, 2010, 01:18:13 PM »
How does the changer work?
« Reply #7 on: March 10, 2010, 02:49:07 PM »
The whole carousel moves over to the spindle.  I am going through the logic right now.
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #8 on: March 10, 2010, 03:17:37 PM »
Do you have any photos?
regards
Boris
« Reply #9 on: March 10, 2010, 04:05:15 PM »
It is a cincinatti Arrow 500.  I just attached a few photos.
Bill
