Hello Guest it is June 09, 2026, 06:12:25 AM
Author Topic: should I reinstall  (Read 21392 times)
Re: should I reinstall
« Reply #10 on: March 04, 2010, 04:12:32 PM »
82% wow, should only be a few % on a machine like that, look at the Processes tab and see what the heck is using all that CPU.
« Reply #11 on: March 04, 2010, 04:16:04 PM »
Mach3.exe, nothing else seems to be even running. Its hitting 100% on its rapid travel back to zero.
« Reply #12 on: March 04, 2010, 04:19:14 PM »
Something weird going on there, even on my pico board the CPU only gets to about 30-40%
What model of Dell is it? Not a fan of Dells but even they shouldnt be that bad ;D
« Reply #13 on: March 04, 2010, 04:29:58 PM »
Well i found out were all my CPU usage was going, in an attempt to try anything i turned my kernel speed all the way up.
For what ever reason it does helps to keep my outputs from turning on when there not suppose to. humm
IDK
josh
« Reply #14 on: March 04, 2010, 05:02:03 PM »
So if you turn the kernel back down to what its meant to be it lowers the CPU but makes the outputs turn on more frequently? Does the code window also stop when the kernel is lower?
« Reply #15 on: March 04, 2010, 05:06:22 PM »
code window?
« Reply #16 on: March 04, 2010, 05:10:53 PM »
code window?
Well I took it thats what you were meaning when you said
I'm having trouble with my G code display screen.  Although the Mach is going through each line of the G code, the display screen  is stopping in the middle and not showing that it is going through each line of G code.
« Reply #17 on: March 04, 2010, 05:13:59 PM »
That has not changed. I took a vid of it i could send it if you like, I should still have your email
« Reply #18 on: March 04, 2010, 05:18:24 PM »
ok
« Reply #19 on: March 06, 2010, 08:07:16 AM »
I loaded a similar g code to the system and problem solved?
thanks for all the help
josh
