Hello Guest it is June 11, 2026, 08:38:33 AM
Author Topic: CSS with Mach3  (Read 12952 times)
CSS with Mach3
« on: March 01, 2010, 06:45:32 PM »
Im wondering if mach3 will work with a vector drive so that I can program CSS on my lathe?
Or is there some other way to do this?
Thanks Mike ???
Re: CSS with Mach3
« Reply #1 on: March 02, 2010, 01:13:25 AM »
If Mach is controlling your spindle well at the moment with the VFD then it should be fine with CSS. I am not sure how well CSS works however, I use the SmoothStepper and it doesnt work quite right but I am not sure if its a Mach or SmoothStepper issue.
Re: CSS with Mach3
« Reply #2 on: March 02, 2010, 04:09:07 AM »
I think a read an earlier thread that it is completely broken in the newer releases of Mach  >:(
Phil
Re: CSS with Mach3
« Reply #3 on: March 02, 2010, 05:50:18 PM »
I use CSS with Mach3 Lathe all the time.
I run a Smoothstepper currently with V015meg Plugin and Mach V3.042.037.  (I notice this morning that Mach3 R3.042.038 is released)
I tried later Smoothstepper Plugins but the all have a problem with indicating True Spindle Speed on the Mach3 DRO.  V015meg Plugin indicates accurate Spindle Speed.
As far as I can recall, CSS worked on my setup with all Mach3 variants that I have used.
I use Mach3s PWM output control to control my Danfoss VFD via a simple RC integration circuit.  Works a treat.
Here it is working.  In the Video I use CSS for the OD turning operation, then switch CSS off to perform the spot drill and drill operations, then switch CSS back on to perform the parting operation.
http://www.youtube.com/watch?v=55SLUjDg5go
Regards
Chrisjh
Re: CSS with Mach3
« Reply #4 on: March 02, 2010, 06:09:07 PM »
Chris maybe you could attach the plugin for some testing please
Phil
Re: CSS with Mach3
« Reply #5 on: March 02, 2010, 09:21:01 PM »
Hi Phil,
Smoothstepper Plugin V015.meg as requested.
Regards
Chrisjh
