Hello Guest it is June 10, 2026, 03:36:22 AM
Author Topic: only 500 lines reeding  (Read 8806 times)
« on: February 18, 2010, 09:57:22 AM »
Good mornining to every one!
Im Eugenio,an old man on the new way;
I made my own cnc router machine,my intension is made an art work on it,
(excuse mine bad english); but I have a problem,program reed only 500 lines:
The machine have 24 x 36 inch working area ;
computer:
           window xp-pck 3,pentium (R) 4 cpu 2.8 Ghz; 1.46 GB 0f  RAM.
Mach 3:
           3.042.020
I made a some hole on the table area wiht G83 AN WORK good but,
can not made a large art work because machine dont reed the program
I have an experience on the cnc programs that was my job for a some years
so I know is no problem with that,if cheked of the plug & play in service configuration
I have full reeding but,have not control over the machine,went I checked on plug & play
I have no reeding (?!) ,I made all changes and optimized window as mach 3 suggest but,
nothing result.
I appreciate,if some body can help me,PLEASE.
note: my e-mail   mastermachining@yahoo.com
Thanks,to every one have good day,
Eugenioo
Re: only 500 lines reeding
« Reply #1 on: February 19, 2010, 06:56:09 AM »
Hola Eugenio.
Para que el programa te lea mas de 500 lineas tienes que comprar el software.
« Reply #2 on: February 19, 2010, 08:11:02 AM »
GOOD MORNING!
Thanks for reeding my post
jdmaya,I buy a program and have a disc licensed to my name,on this disc are somes version
of the program I used every one, but nothing help.
Eugenio.
« Reply #3 on: February 19, 2010, 03:25:00 PM »
Si compraste el software debes tener el archivo Mach1Lic.dat, este archivo debe estar guardado en el directorio mach3.
En el software mach3, menu help - about mach3 controller, aparece licensed to: nombre de la licencia (tu nombre o empresa).
« Reply #4 on: February 20, 2010, 09:08:44 PM »
Muchas Gracias,eso mismo era,no tenia ese archivo lo copie del disco y listo.
Gracias,Eugenio
