Hello Guest it is June 09, 2026, 02:26:39 PM
Author Topic: Program Safety Lockout problem  (Read 47405 times)
Re: Program Safety Lockout problem
« Reply #40 on: September 09, 2010, 02:28:27 PM »
plus I owe you that pint ( not water) - wasn't thinking it could be the install
saved me some time
« Reply #41 on: September 09, 2010, 03:14:59 PM »
Ha ha yes have used Jasons reader since its beta days :)
Good to hear its working now, not sure if its a corrupt Mach as the install over the top should have done the trick. When you say another machine I presume you mean another computer? If so I suspect there is maybe something in the first one stopping the xml getting written correctly when shutting down Mach.
Afraid I dont drink so you will just have to have that pint yourself :)
« Reply #42 on: September 09, 2010, 04:04:24 PM »
well not sure its in the xml ok so I suspect your right just going to install an clean image an start again. I have a few Dll might be interfering so I remove the drivers
« Reply #43 on: September 09, 2010, 04:35:16 PM »
Let us know the outcome :)
