Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 25, 2012, 09:01:55 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
Mach SDK plugin questions and answers.
Finished Plugins for Download
Huanyang VFD controller plugin
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
Go Down
« previous
next »
Author
Topic: Huanyang VFD controller plugin (Read 33679 times)
alexd
Active Member
Offline
Re: Huanyang VFD controller plugin
Reply #290 on:
October 25, 2011, 04:23:55 PM »
Went through a lot of pages on this forum and others like cnczone but couldn't find solution.
My problem is following:
1. I'm using 1.5kW VFD connected via 232-485 DIY adaptor to PC running Mach3 with "Huanyang VFD controller plugin" from this thread (many thanks to Matty Zee!!!)
2. I can start spindle from Mach3 clicking "Spindle CW F5" or F5 key
3. I can change spindle speed typing it or clicking + or - in "spindle speed" section.
+++ 4. I cannot stop it clicking on "Spindle CW F5"
+++ 5. I cannot stop it pushing my red EStop button (hardware).
+++ 6. Spindle doesn't stop at program and.
7. I can stop it only clicking "Reset" (sooftware, in Much3)
+++ 8. I cannot see real RPM in "RPM" field in "Spindle speed" section
RS-232 - is native port on motherboard (not USB-232 adaptor). 232-485 adaptor is made by myself using ADM485+ADM232. Checked by oscilloscope - all signals go in right way.
In settings I can see "2" and "2" in PD001 and PD002 fields. "Spindle speed DRO" is checked, "1002" - unchecked at right.
How can I solve +++ items?
thanks,
Alexey
Last Edit: October 25, 2011, 04:25:39 PM by alexd
alexd
Active Member
Offline
Reply #291 on:
October 31, 2011, 03:49:18 AM »
may be it'll help somebody:
Here you may find working 232-485 adaptor
. I didn't use LEDs and SPs. So total cost ~2.5$
Sorry to say - I forgot to uncheck "disable spindle", and now I can start/stop/change RPM from mach3. Spindle stops when program ends.
But hardware "EStop" button still doesn't stop spindle. Thinking to make double wire directly to VFD.
Using
screen designer
changed "RPM" field's OEM code to 1002 and now I can see in this field real RPM coming from VFD.
jafc76
Active Member
Offline
Reply #292 on:
October 31, 2011, 04:38:08 AM »
You should use an output of the BOB with a relay to start and stop, I explained it in this post.
mikemaat
Active Member
Offline
Reply #293 on:
December 07, 2011, 03:09:48 PM »
New member. Got my VFD today. Came with a decent engrish manual complete with error codes. Also had hot glue dabs on the sides of the ribbon connectors to make sure they stayed put. Looks like pretty good quality. I took a picture of my board and it looks like I have the RS485 chip and the relay on my board unlike many other ones. The slot for "CN4" is missing something, but it appears to be missing on every VFD pic ive seen. Will this be an issue for RS485 communication?
Also, I have my computer motherboard, stepper power supply, and stepper drives in a big 24x24x10 control box. Will I have major noise issues mounting the VFD inside it with them, or will some EMI snap on filters take care of that? Id prefer to mount the VFD in the box and keep everything together if I can do so without too much noise. Gonna have to rearrange the box a bit though. Pics attached..
Matty Zee
Active Member
Offline
Reply #294 on:
December 08, 2011, 06:13:56 AM »
From my experience, the EMI from these VFD's are transmitted along the wires. Physical separation has little effect. Make sure you have a decent toroidal ferrite on the motor wires. I wouldn't rely on those clip-on ones but i think some people have got them to work. I think you should be fine putting it on the same box. Heat/thermal issues may be a different story.
Again, this is just form my experience....
Matt
mikemaat
Active Member
Offline
Reply #295 on:
December 08, 2011, 12:02:02 PM »
Sounds good, thanks. Im waiting on the RS485 converter, then ill get this stuff mounted and try it out. Will post up here on how I make out.
Also, is that missing item on CN4 an issue or is that normal? The rest of the board looks complete.
EVguru
Active Member
Offline
Reply #296 on:
March 29, 2012, 11:03:04 AM »
Quote from: majorstrain on March 07, 2011, 07:40:10 AM
I think the resistor pair R8a,b and the relay K1 were meant to be in rush protection for the capacitor bank, but it should have been inline between the bridge and the positive side of the capacitors to be effective. That's why the relay has been hard wired to be energized all the time. To get around this error the have probably used high ESR capacitors in the bank.
Just been reading through this thread as I've been looking into adding the braking components.
My take on the relay and resistors is that they're part of a shorted power stage detect. If one of the half bridges has shorted out, then the resistors limit the fault current.
Paul Compton
www.morini-mania.co.uk
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
