Hello Guest it is June 09, 2026, 03:27:02 PM
Author Topic: Huanyang VFD controller plugin  (Read 1202340 times)
0 Members and 19 Guests are viewing this topic.
Re: Huanyang VFD controller plugin
« Reply #140 on: September 02, 2010, 05:47:09 AM »
Hi Rognets,
Good to hear that the Max485 works as I am still waiting for mine to arrive so I can install it on the board.
BTW, can you check to see if tou have the two relays in the lower left corner of the board.  They are labelled as GDQ1 and GDQ2.  I am missing GDQ1 and would like the specs on it.
There is a link to a picture of my board and missing parts in a previous post.
Thanks, Clayton
« Reply #141 on: September 03, 2010, 01:57:06 AM »
Clayton
I have looked and there is one relay only, the one on the Right Hand side. The one to the left is vacant.
Steve
« Reply #142 on: September 03, 2010, 05:30:59 AM »
Thanks.
The relay  on the right is missing from my unit.  I guess it doesn't matter as long as there is one????
Clayton
« Reply #143 on: September 03, 2010, 05:48:14 AM »
You don't need either for the VFD to function. They are for auxillary outputs.
One is a single throw double pole and the other a single throw single pole from, memory. Check the manual its clearly descibed and shown on the schematic.
« Reply #144 on: September 03, 2010, 05:58:30 AM »
Thanks for the information - it is good to know that all is well with my VFD.  I will definitely take a closer look at the manual as you have indicated.
I am still waiting for the Max485 unit to arrive so that I cann complete the repair.
Clayton
Offline mikie
  •  18 18
« Reply #145 on: September 05, 2010, 02:46:59 AM »
My max485 chips have arrived so can someone tell me where pin1 is so I can work out which way to orientate the chip on the board
Michael
Offline DMBGO
  •  201 201
  • Time is the same in a relative way
« Reply #146 on: September 05, 2010, 07:44:16 AM »
Here is a link to the datasheet, the pinouts are on page 18
http://www.datasheetdir.com/MAX485+download
David
Offline mikie
  •  18 18
« Reply #147 on: September 05, 2010, 06:25:42 PM »
Sorry my question was not correctly worded. I'm after the orientation of the chip on the VFD board. Which way do I place it on there to solder it on. My assumption is the chip has a dot to indicate pin one.
Offline DMBGO
  •  201 201
« Reply #148 on: September 06, 2010, 12:14:45 AM »
I haven't got mine apart at present, but the rule for circuit boards is that all chips face the same way, so if there is another chip on the board, you with the same orientation, you should put this chip around the same way.
I'll take the cover off mine and check anyway in a little while.
David
« Reply #149 on: October 31, 2010, 05:21:10 PM »
hey guys
just wondering if my computer had a serial port on board can i just use a 9 pin solider on connector and solider 2 wires with the connector and attach them to the VFD ?
if i can do that do u know which pins i use ?
thanks
Justin
