Hello Guest it is June 09, 2026, 06:54:53 PM
Author Topic: uninstall?  (Read 11548 times)
uninstall?
« on: September 27, 2006, 06:40:44 AM »
Hi I installed Mach on my laptop here at work so I could look at the new screens . I'd like to uninstall now because windows keeps trying to install new hardware it calls mach3 driver  . can anyone tell me the procedure for uninstalling it ? I don,t see it listed as an installed program in the add or remove programs window. thanks Bob
ynneb
Re: uninstall?
« Reply #1 on: September 27, 2006, 07:40:50 AM »
Right click on MY COMPUTER select PROPERTIES / DEVICE MANAGER/ find the MACH ENGINE and righ tclick on it and delete.
Something like this anyway.
Re: uninstall?
« Reply #2 on: September 27, 2006, 09:34:48 AM »
I tried that and I'm not getting the delete option any other Ideas?
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
Re: uninstall?
« Reply #3 on: September 27, 2006, 01:05:09 PM »
HI, In the device manager look for the "Mach X pulsing Engines"  Click on that it will drop down and Give you the Mach3 Driver. Right click on that and select 'uninstall' that should take care of it. Do a reboot and you should be good to go..
Chad
Re: uninstall?
« Reply #4 on: September 28, 2006, 06:52:42 AM »
Hi Chad that worked thanks alot Bob
Offline chad
  •  361 361
Re: uninstall?
« Reply #5 on: September 29, 2006, 12:22:36 AM »
No problem
Chad
