Hello Guest it is June 10, 2026, 03:03:42 AM
Author Topic: Turn + Threading problems  (Read 32917 times)
Offline DAlgie
  •  314 314
    • Algie Composite Aircraft
Re: Turn + Threading problems
« Reply #20 on: July 02, 2010, 09:24:42 AM »
Thanks Hood, Rich, will give that a  try. Save XML to another folder first and then put that back in the right place after installing that version Mach again?
« Reply #21 on: January 30, 2011, 01:07:03 PM »
Hello. I have a question about disk to recognize velocity and position of spindle. At older versions of mach I could use disk with some slots and one wider. Now i had to change PC in my turning machine and install the newest mach,but It works with one slot only! I dot like it. From time to time I have to cut thread on quit big pipes (~10"), then speed of spindle is rather low (~50 RPM). In spite of high power of spindle motor - 10HP, the rpm is not so rigid and plays according size of chips. At low spindle speed, it makes problems, thread is imprecision. So do you have any ideas to solve this problem?
Regards Marek.
« Reply #22 on: January 30, 2011, 04:21:57 PM »
Can you attach your xml please.
« Reply #23 on: February 01, 2011, 02:16:02 PM »
Yes, of course, see my XML attached.
I still can not understand why is changed measuring spindle's velocity. Does any body could explain me?
Regards Marek.
« Last Edit: February 01, 2011, 02:17:46 PM by margor »
« Reply #24 on: February 01, 2011, 02:23:47 PM »
You have your Index Debounce set to 50, try setting at 0
« Reply #25 on: February 07, 2011, 09:40:10 AM »
We are rookies to Mach 3 Turn and would like to learn how to use the threading wizard, is there a tips and tricks section on the setups? Highland Community College Technical Center
« Reply #26 on: February 07, 2011, 09:45:01 AM »
http://www.machsupport.com/forum/index.php/topic,13017.0.html
RIch did a write-up here, might help ya.
Look through the other Members Docs at the bottom of the HOME page.
Russ
« Reply #27 on: February 07, 2011, 10:37:23 AM »
Thanks we will check it out.
« Reply #28 on: February 07, 2011, 04:11:58 PM »
MARGOR,
I dot like it.
Dosen't matter if you like it or not, it is the way it is. There is no advantage to multiple slots as compared to a single slot.
Adjust the type of thread cut or the depth such that rpm is stable or at least dosen't vary significantly.
« Reply #29 on: February 07, 2011, 04:22:04 PM »
I think everything you need to know is in the write up. There is nothing special about the using the wizard. You basicaly turn down your piece to a correct diameter, deifine the pitch and how far you want to thread,
the Z start should be about 3 to 5 x pitch to allow for aceleration, x end is  depth  of the thread  ( and for a SHARP V THREAD     DEPTH=.866P ).
