Home
Downloads
Mach and LazyCam
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Links
User Reviews
User Videos
Contact Us
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese Forum
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
September 02, 2010, 07:40:08 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
Brains Development
I'm out of OEM Triggers
Pages:
1
Go Down
« previous
next »
Author
Topic: I'm out of OEM Triggers (Read 545 times)
marclingling
Active Member
Offline
on:
February 06, 2010, 05:26:11 PM »
I used up all 15 of the oem triggers and would like to know if it's possible to use brains and pokeys to add more trigs.
My problem is I can't figure out how to make mach see the inputs from the pokeys.
Is there a mod address assigned to every pokeys pin or only the analog pins (43-46)?
The brain I am trying to do is basically:
Pokeys pin x.....No op pass through.....Button press
Can this be done outside the 4 analog pins?
Thanks in advance,
Marc
ostie01
Active Member
Offline
Re: I'm out of OEM Triggers
Reply #1 on:
February 06, 2010, 06:05:45 PM »
Could you only assign hot key to the pokeys input.
Jeff
marclingling
Active Member
Offline
Reply #2 on:
February 06, 2010, 08:02:26 PM »
Actually, I'm trying to set jog increments with external buttons and as far a I am aware, there is no hotkey for that function.
Thanks for the reply
Marc
ger21
Global Moderator
Offline
Reply #3 on:
February 06, 2010, 10:29:56 PM »
I set up a small macro and use a single button to cycle through 5 increments. Would that work for you?
marclingling
Active Member
Offline
Reply #4 on:
February 06, 2010, 11:45:40 PM »
Quote from: ger21 on February 06, 2010, 10:29:56 PM
That's probably what I'm going to end up doing as well.
I hoped that I could do it using brains because I've already wired three rotary switches that will have to be undone/removed from my control panel......bummer
Thanks for the reply,
Marc
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline
Briceville, TN, USA
Reply #5 on:
February 07, 2010, 04:41:01 PM »
yes you can extend the stuff ad-nausium......
in the "PoKeys.set on the pokeys page, with the combination of the poKeys config, you can assign your inputs,
to trigger User LEDs, in a range (2 ranges of inputs possible).
Then In Brians, look at the Uled that represents that PK Pin, do a no op, then to a button press.
IF the button priess you want is NOT in Brians, that is ok, cause you can use MacroPump to with the DoButton(*********)
OEM code to press buttons from the macro pump.
scott
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, Controls, PLCs, Macros, ATC's, machine build, retrofit or repair.
marclingling
Active Member
Offline
Reply #6 on:
February 07, 2010, 07:52:29 PM »
Quote from: poppabear link=topic=14070.msg92913#msg92913 date=1265578861[quote author=poppabear on February 07, 2010, 04:41:01 PM
scott
Thanks I will give this a try
Marc
marclingling
Active Member
Offline
Reply #7 on:
February 08, 2010, 03:17:09 PM »
Quote from: poppabear on February 07, 2010, 04:41:01 PM
scott
Scott,
I just wanted to report back and say "Thanks". I got it working following your instructions and I would have never figured it out without your input.
Thanks again,
Marc
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> dspMC/IP motion controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Loading...
