May 25, 2012, 08:23:25 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Works in progress
| | | |-+  4 axis screens for 800x600 display
Pages: « 1 2 3 4 5 6   Go Down
Print
Author Topic: 4 axis screens for 800x600 display  (Read 5015 times)
fever16
Active Member
Offline Offline
View Profile
« Reply #50 on: May 12, 2010, 10:15:59 PM »
Thanks.
and also i tried your screen,the spindle/ATC page is complete blank.and the diagnostics page font is too small.imean input and output text isl small.
will be waiting for the JOG screen.mine is touch screen.always wanted to have a separate screen with big buttons and with all jog settings (step and velocity etc).
zafarsalam
Active Member
Offline Offline
View Profile
« Reply #51 on: May 12, 2010, 11:25:19 PM »
Give me a week. I am busy these days with designing a custom 6 axis screen.
Zafar
fever16
Active Member
Offline Offline
View Profile
« Reply #52 on: May 31, 2010, 10:21:12 AM »
i would like to suggest some more modifications
for touch screen and 3 axis router,i would be much better if you remove 1st page (setup) and spindle page.add the MDI command line to your existing 3rd page.
and place the spindle override an feed rate override in the same page.
diagnosis page is not that important but Jog screen with Big buttons are very important.
zafarsalam
Active Member
Offline Offline
View Profile
« Reply #53 on: June 24, 2010, 10:15:08 PM »
Here's a screen set which I am using at my shop floor. It has Xbox 360 hand held controller support. I use this controller with an excellent plugin programmed by Lee Davis. The macros used with these screens are included in compressed file. The config screen for Xbox 360 is also included. I use the back and start buttons for activating the macros. The back button loads the Xbox screen on which X0, X/2, Y0, Y/2 and Z0 are selectable with the back button on Xbox. The Start button executes X0, X/2 .... commands which zeroes and halves the X axis. Similar functions for Y and Z axes. Basic idea is that I can locate and center a job on the machine bed without the need to reach out to the keyboard on the control panel. Very useful for large machines.
For installation, uncompress the files in Mach3 folder. The digital-7.ttf font file goes into the windows/fonts folder and in the Function Cfg's/Fonts menu in Mach3 select digital-7 as the font for DRO's to get the desired effect. Screenshots at http://www.machsupport.com/forum/index.php/topic,12753.msg100682.html#msg100682
Zafar
* k05b.rar (973.18 KB - downloaded 76 times.)
zafarsalam
Active Member
Offline Offline
View Profile
« Reply #54 on: August 04, 2010, 05:14:19 AM »
Here is the complete 1024x768 screen set. It is similar to the previous KC05 except that it has the jogging screen which is suitable for touchscreens. Follow the instructions in previous posts for installation.
Zafar
* KC05c.rar (632.88 KB - downloaded 72 times.)
Pages: « 1 2 3 4 5 6   Go Up
Print
Jump to:
