May 25, 2012, 08:08:41 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  NC Pod (Moderator: kookaburra)
| | |-+  Ncpod is not recognized
Pages: « 1 2   Go Down
Print
Author Topic: Ncpod is not recognized  (Read 3157 times)
raccawasaki
Active Member
Offline Offline
View Profile WWW
« Reply #10 on: March 03, 2010, 01:43:05 AM »
yes i use the build in homes.. but it needs a input signal
in "plugin control" then you can choose which homing you choose
i use single stage
Ralf
Ralf Klaassen Timmerwerken
www.ralfklaassentimmerwerken.nl
giordano
Active Member
Offline Offline
View Profile
« Reply #11 on: March 29, 2010, 04:37:20 PM »
Hello. Now use a card controlled by the parallel port, but if you improve the performance of my CNC I bought a card NCPOD. Could you help me understand how to make connections? I followed the two links below:
http://221.132.159.78/forme/up/ncPOD/00.pdf
Setting of Mach
http://221.132.159.78/forme/up/ncPOD/Mach3Mill.xml
but it seems not work. Could you send me the relevant files? Thanks in advance. Greetings. Giordano
gernap
Active Member
Offline Offline
View Profile
« Reply #12 on: April 03, 2010, 02:30:23 AM »
hi,
i did follow this topic, because i am building my own gantry cnc and have already my drivers contrloled by nc pod,at awesome speeds
I'm still finetuning my inputs and outputs in Mach3 "blue screen"
My problem...Z-zero doesn't work, my axes are not moving when i start the script ( same script used with LPT driver, Did work fine)
But with NcPod it's not working (pod pin=3 / mach3 port=1 pin=3) in mach screen when testing contact the light comes on but when push button to start the script ,the script is stops working
I'm using Vista on my laptop with mach3 and the latest firmware on the Pod
help  Huh
raccawasaki
Active Member
Offline Offline
View Profile WWW
« Reply #13 on: April 04, 2010, 04:19:54 AM »
I believe pin 3 is for emergency
and pin 2 for the probe
the rest of the pins you can decide for yourself
If i am correct!!!
Greetz,
Ralf Grin
gernap
Active Member
Offline Offline
View Profile
« Reply #14 on: April 04, 2010, 04:38:16 PM »
is the documentation wrong ?
raccawasaki
Active Member
Offline Offline
View Profile WWW
« Reply #15 on: April 07, 2010, 11:17:33 AM »
i am sorry guys,  i mean pin 2 is emergency button and pin 3 is z zero/probe
i have the documentation included
greetz
Ralf
* NcPodUserManual.pdf (698.11 KB - downloaded 104 times.)
gernap
Active Member
Offline Offline
View Profile
« Reply #16 on: April 07, 2010, 04:52:56 PM »
the strangest thing about it is, when i change the G31 code into G01, the script works and the axis are moving (only stops moving on E-stop)
does the NcPod have no support for G31?
Pages: « 1 2   Go Up
Print
Jump to:
