Hello Guest it is June 09, 2026, 07:48:26 AM
Author Topic: Highlighted Text  (Read 22982 times)
Highlighted Text
« on: January 31, 2010, 09:13:15 AM »
Klaus
When running the standard mill screen in Mach there are the page buttons at the top of the screen.
The text on them is highlighted for the button that the page is on.
Would it be possible to add that or is there a way to do that already ?
Phil
Re: Highlighted Text
« Reply #1 on: January 31, 2010, 11:50:20 AM »
Hi Phil,
thank you for your proposal. MachScreen doesn't show the "screen select buttons" in a different way when a page is selected. To do that it would need a lot of programming. At the moment this feature is not on my to do list.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: January 31, 2010, 01:40:41 PM »
OK thanks
Phil
