May 25, 2012, 08:07:18 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Launch app from a button
Pages: 1   Go Down
Print
Author Topic: Launch app from a button  (Read 473 times)
rrc1962
Active Member
Offline Offline
View Profile
« on: January 29, 2010, 11:35:52 AM »
I'm trying launch an external app from a button using VBScript.  the following code is supposed to work but doesn't on a Mach screen.  Can anyone point me in the right direction?  Perhaps there is another way to launch an app from within Mach using a button or menu item?
Dim commandLine, WshShell
   commandLine = "C:\app.exe"
   Set WshShell = Server.CreateObject("WScript.Shell")   ' I get object not supported error on this line.
   Call WshShell.Run (commandLine,8,true)
   Set WshShell=Nothing
DaveCVI
V4 Screen Contributor
Offline Offline
View Profile WWW
« Reply #1 on: January 29, 2010, 12:13:15 PM »
HI,
Here's a code fragment I use for launching acrobat reader to open a doc file:
Option Explicit
' code to open the pdf User manual
Dim CmdString As String
Const Filename = "C:\Mach3\Documentation\machStdMill\MachStdMill User Manual.pdf"
Const AppFQFN = "C:\Program Files\Adobe\Reader 8.0\Reader\AcroRD32.exe"
CmdString = """" & APPFQFN & """" & " " & """" & FileName & """"
Shell(CmdString)
www.CalypsoVentures.com
Pages: 1   Go Up
Print
Jump to:
