Home
Downloads
Mach and LazyCam
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Known Bugs
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
February 12, 2012, 08:50:35 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
There is a God!!!!!Keygrabber Axis Gain question
Pages:
1
2
3
4
5
6
Go Down
« previous
next »
Author
Topic: There is a God!!!!!Keygrabber Axis Gain question (Read 17831 times)
sshneider
Global Moderator
Offline
Re: Keygrabber Axis Gain question
Reply #20 on:
October 03, 2006, 11:35:13 AM »
Check out this thread regarding info on the Shuttle Pro
http://www.machsupport.com/forum/index.php?topic=1220.0
Sid
Chaoticone
South Carolina, US
Administrator
Online
Precision Chaos
Reply #21 on:
October 06, 2006, 04:12:59 PM »
Thanks Sid,
I checked that out. It looks pretty neat. I just wish I could get the game pad right. I think it is a bug with Mach or Keygrabber. It does exactly what I want it to do to the second axis I command but not the first. That is if you are moving more than one axis simultaneously.
If you could see the things I have in my head, you would be laughing too.
www.precisionchaos1.com
creep_pea
Active Member
Offline
Reply #22 on:
October 09, 2006, 06:18:12 AM »
Hi
I think I might of sorted it, I updated the video card drivers for the lastest ones this morning and it seams a lot better, but it's still not good enough for me to be confident using one of the buttons as a stop or feedhold button. You can sometimes flick the button on and off quick enough that the keygrabber doesn't respond.
I tried setting up one of my axes as a axisgain to see if I could help Brett out with his problem but I too had no joy getting it to work I could even get it to work on a second axis as Brett does as my will only let me move one axis at a time.
Chris
Chaoticone
South Carolina, US
Administrator
Online
Precision Chaos
Reply #23 on:
October 09, 2006, 07:33:24 AM »
Hi Chris,
I know I've asked before, but are you sure your intial delay in misc. settings (in keygrabber) is set to 300? I wish I had a gamepad that would plug in to my gamecard, all of mine are usb. How big is the delay? 1sec., 5sec., 1/2 sec. ?
Guest
Reply #24 on:
October 10, 2006, 04:10:24 PM »
Have sent you a PM
Chaoticone
South Carolina, US
Administrator
Online
Precision Chaos
Re:There is a God!!! Keygrabber Axis Gain question
Reply #25 on:
October 13, 2006, 05:10:38 AM »
I got it!!!!!!!
It was so d%$# simple. In Keygrabber, joysticks, you set up the axis you want to be your axis gain as selectable axis!!!!! I Changed some other stuff too. I'll post more later.
zarzul
Active Member
Offline
Wyoming, USA
Re: There is a God!!!!!Keygrabber Axis Gain question
Reply #26 on:
October 13, 2006, 10:54:01 AM »
I am interested in your setup, I have used a gamepad with some success but not as well are you seem to be doing.
Can you post your *.grab file, it is were keygrabber saves your settings.
Thanks Arnie
Chaoticone
South Carolina, US
Administrator
Online
Precision Chaos
Reply #27 on:
October 13, 2006, 12:12:24 PM »
Here is a copy of my grabber file and my screen set. I changed some of my hotkeys. I will be posting in more detail later. If you can't find your way around screen designer, please wait until I get everything posted.
I also changed the way I was using the last axis. I know this is confusing but I will clear it up in detail later.
I find the keygrabber to be really nice and easy to set up. It's killer. I can do the following from a $16.00 gamepad I bought at Walmart.
1,2,3. Jog my X,Y,&Z in analog. Slow to fast.All three at the same time.
4,5,6. Zero my X,Y,&Z axis DROS with an interlock.
7,8,9. Feed rate +,-,& instant return to 100%
10. Step mode. This works good.
11. Go to Zero with an interlock. Sends all three axis home.
12. Program rewind.
13. Cycle start.
14. Feed hold.
15. Cycle stop.
16. Flood coolant toggle. On,off.
17. Single block.
18. Block delete.
19. Optional stop.
20. Toggle through step mode rates.
More info. to come later.
Last Edit: October 14, 2006, 09:56:44 AM by Chaoticone
Chaoticone
South Carolina, US
Administrator
Online
Precision Chaos
Reply #28 on:
October 14, 2006, 09:40:58 AM »
Latest screen set, grabber file, and screen pics.
1024.set
(97.32 KB - downloaded 308 times.)
Default.grab
(1.78 KB - downloaded 386 times.)
Last Edit: October 14, 2006, 09:55:05 AM by Chaoticone
Chaoticone
South Carolina, US
Administrator
Online
Precision Chaos
Reply #29 on:
October 15, 2006, 09:17:29 AM »
I have a little more info. The right joystick, left to right is the one we use for axis gain and other things. 1st, In screen design, set your Jog mode button to Hot key Ctrl J.
1. In neutral = 1st axis rapids, second and third moves at slow jog rate. Pull up this page by hitting tab key in Mach. Double click this number and change to 1.0 % and hit enter or, raise and lower by the [ and ] keys.
2. Hold to right = All 3 axis in rapid
3. Hold button 6 ( interlock ) and hold right (in that order) = Step mode
4. Hold button 6 ( interlock ) and bump left (in that order) = Changes cycle jog step from 1.0000 - 0.0001 by one decimal place per bump.
Pages:
1
2
3
4
5
6
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP motion controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Loading...
