Hello Guest it is June 09, 2026, 07:37:06 PM
Author Topic: Need help with basic VFD spindle setup - 0 to 10 VDC, Forward & Reverse  (Read 15933 times)
I've got my Shizuoka mill moving on all three axis well, but I need help getting the VFD driven spindle working in Mach3.
I'm using a 1750 ISA card with ICM2900 terminal board.  In the plug-in, I have the spindle set up to use axis W as a servo motor (I do not have an encoder on the spindle).
I wired the VFD 0 to 10 VDC input to the W servo motor output and return on the ICM 2900.
I am confused on how to wire the VFD Forward and Reverse inputs and what the settings should be in Mach3 for a basic VFD set-up.
Any help is appreciated.
Jim
Re: Need help with basic VFD spindle setup - 0 to 10 VDC, Forward & Reverse
« Reply #1 on: January 24, 2010, 02:59:21 PM »
Well, I figured out how to get the M3 and M4 commands to work thru outputs 5 & 6, but I still can't figure out a way to get a 0 to 10 VDC output (on axis W driving the spindle) signal to the VFD and have it equate to 330 - 5380 RPM.  I have changed all the pulley ratios (1 to 15) in Mach3 so that they are the same.
I wish I had an encoder on the spindle as that probably would work quite easily with the plug-in.
Anybody out there with suggestions?
Jim
« Reply #2 on: January 24, 2010, 03:27:33 PM »
If you get the 0 to 10V output to work out from your terminal board then you have to configure the VFD to run 330rpm at 0V and 5380rpm at 10V. All VFD's I have been working on have a lot of parameters making all such sort of setups possible.
« Last Edit: January 24, 2010, 03:29:58 PM by SteinarN »
« Reply #3 on: January 24, 2010, 03:55:01 PM »
I have the parameters in the VFD setup correctly.  I've verified it by using a manual potentiometer connected to the VFD.
My question is how to set up the plug-in and Mach3 so that say a M3 S5380 command sends a 10 VDC signal out.
I have the plug-in set to use axis W(D) for the spindle and it is set as a servo.  I do not have an encoder, so I have left that box un-checked.  Should I put any values in the encoder specs?
In Mach3, how do I set up the spindle?  Do I enable the spindle and select the step/dir or PWM boxes?  I've set all the pulley ratio tables to the same values of 330 min and 5380 max.
« Reply #4 on: January 26, 2010, 04:38:08 PM »
jj83002,
I had the same problem just today.
I'm more of a Galil guy then a Mach3 guy (first time user)
So.....
I wrote a little galil program which is always running.
It checks for a change in the OF command and then
manipulates the Mach3 value to get the desired value
and then resets the OF command with the new value.
I set various Mach3 speeds and measured the results with a tach.
In my case it was very linear so I just used y=mx+b. Any formula
could be used.
#AUTO                                             ***Auto label, runs automatically at power on
SHF                *** My spindle is the F axis
CURRENT=_OFF                                 *** Set a variable equal to the current offset at power on
#LOOP                                             *** Loop Label
IF (CURRENT=_OFF)                           ***Is the variable equal to the current offset?
JP#LOOP                                          ***If yes, check again
ELSE                                                *** If no....
IF (_OFF=0)                                      *** If the current offset is zero just set the variable
CURRENT=0                                      *** to zero
JP#LOOP                                          *** Check again
ENDIF
TEMP=(((_OFF*100)+133.333)/15.933)/100    *** Calculate desired offset in variable TEMP
OFF=TEMP                                                   *** Set the F axis Offset to TEMP
CURRENT=_OFF                                            *** Set the Variable CURRENT to the new Offset
ENDIF
JP#LOOP                                                     *** Do it again
EN
