Hello
Guest
it is
June 09, 2026, 06:52:49 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Acceleration problem
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Acceleration problem (Read 20162 times)
faby
74
Re: Acceleration problem
Reply #10 on:
September 23, 2006, 12:55:01 PM »
Ok, I think you are on the right way...
In the software that I'm using for 5 years, there's something like "angular discrimination", that set where place a curve, or a deceleration, and where not.
There's a way in mach3 to modify that value?
Faby
fdos
326
Reply #11 on:
September 23, 2006, 03:16:50 PM »
This is a question for Art I think!
You can see the same if you move one axis backwards and forwards the same distance(say -100mm to +100mm to -100mm)and keep repeating . as you increase the feedrate the distance moved becomes shorter and shorter.
Wayne....
Last Edit: September 23, 2006, 03:19:04 PM by fdos
faby
74
Reply #12 on:
September 24, 2006, 04:00:07 AM »
Mhh I'll try...
I tried to increase the acceleration ramp and my square become magically a circle.
I'll wait for an art answer
I'm sure that they could solve it
Brian Barker
3,860
Reply #13 on:
September 24, 2006, 03:16:00 PM »
There is the angle and the CV feedrate on the settings page
With this you can set the MAX CV feedrate that that will change the size of the Arc from move to move.
Hope that helps
Brian
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
2
Go Up
« previous
next »
