Hello Guest it is June 10, 2026, 01:40:32 PM
Author Topic: Index Pulse Help!  (Read 11191 times)
Index Pulse Help!
« on: January 20, 2010, 01:47:45 PM »
I want to use an index pulse with my lathe.
I don´t have alot of experience about this and would appreciate some help.
This is the "component" i´m using... http://www.everlight.com/upload/product_pdf/ITR8102.pdf
I´ve connected it to the breakout board MB-02 on the smoothstepper and
get a correct reading in between ALOT of "jitter".
How do i get rid of this jitter?
Do i need pull-up or pull-down resistors?
Someone told me that the index pulsel MUST be active low, is this true?
As it is now i believe the signal is active high since i use an index disc with a slot once/turn!
Re: Index Pulse Help!
« Reply #1 on: January 27, 2010, 06:10:04 AM »
Afraid I cant help regards your specific opto but I can tell you that it is not true that you need active Low for it, all 4 of my machines that use the SS have the Index active High.
