Hello Guest it is June 09, 2026, 06:57:58 PM
Author Topic: A Lathe Question For Hood  (Read 8437 times)
« on: January 15, 2010, 12:02:59 PM »
Others can answer too. ;D
I am using the front toolpost, the tool that i want to use is a triangular tip tool.
The way it's mounted in the toolpost it could be used as a facing tool and turning tool
It could also be used as a boring tool over the centreline albeit with the chuck running in reverse.
So would the second description be classed as a rear toolpost setup
Phil
Re: A Lathe Question For Hood
« Reply #1 on: January 15, 2010, 12:21:38 PM »
I'd say no.
X values would just be -.
« Reply #2 on: January 15, 2010, 12:22:07 PM »
At the moment you need to have all tools designated the same, either all front or all rear so you would if using in the front post either use the G51X-2 and code positive values for the X or code negative values with no X scaling in effect..
In the future you will be able to designate front/rear and what that will hopefully do is autoswap the X axis direction so that all coding will be positive values unless you specifically want and write them as negative values.
« Reply #3 on: January 15, 2010, 12:56:00 PM »
I just tried it, cutting air it worked perfectly.
Just a change of M3 to M4
Phil
