Hello Guest it is June 09, 2026, 02:34:25 PM
Author Topic: Input Configuration  (Read 10688 times)
Input Configuration
« on: January 12, 2010, 01:51:00 PM »
Hi, I am using a Galil 1750 controller with sinusoidal comutation on the X and Y axis. I have downloaded the latest version of Mach3 and the Galil plugin. I am not sure how to configure the inputs on the Ports and Pins screen of Mach. Only inputs #1 to #4 are listed, how do I configure inputs #5 to #8 and what is the best way to configure the E-Stop input?  Thanks Kit
Re: Input Configuration
« Reply #1 on: January 15, 2010, 05:23:37 AM »
Kit,
If you look where you downloaded plugin there is a pdf file that explains the I/O numbering.
Darek
« Reply #2 on: January 23, 2010, 02:12:24 AM »
The pdf HillBilly refers to does indeed explain the I/O numbering, for Input1 thru 16. Unfortunately my question referred to Ports and Pins screen of Mach which only lists Input1 thu 4, so my question remains, how do I allocate pin numbers to Inputs5 thru 16? Am I being even more dense than usual?
« Reply #3 on: January 23, 2010, 06:39:23 AM »
OEMTriggers can be used for the rest. BRAINS or VB will handle the logic.
I would not say dense, it is kinda scattered. Hopefully Mach3 ver4 will handle this differently.
Darek
