Hello Guest it is June 09, 2026, 09:03:31 AM
Author Topic: stepper motors rotates only in one ways  (Read 8014 times)
Offline dinko
  •  12 12
    • Bavant.eu
« on: January 09, 2010, 09:19:30 AM »
Hello!!
I'm new in this thing..
i bought some 3 axis controler..but i have some problems:
when i test to rotate wint Keys on screen works only on one way :
X works only in -x way
Y works only in -y way
Z works only in -z way
in + ways dont work... why
thanks (& sorry about my language)
greetings from slovenia!!
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: stepper motors rotates only in one ways
« Reply #1 on: January 09, 2010, 09:27:51 AM »
Well, it could be any of the following -
1) Stepper wires hooked up incorrectly. Having one wire loose can cause a motor to only rotate one direction.
2) You 'Direction' pin assignment in 'Ports&Pins' is incorrect.
3) You have the system Hotkeys assigned incorrectly.
Happy machining , Jeff Birt
« Reply #2 on: January 09, 2010, 09:40:04 AM »
Another thing could be that your stepper drives can be configured for either Step/Dir  or CW/CCW. If that is the case then you may have them set to CW/CCW by mistake.
