February 12, 2012, 08:46:34 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Galil (Moderators: smurph, kcrouch)
| | |-+  Mach3 + Galil
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 »   Go Down
Print
Author Topic: Mach3 + Galil  (Read 41998 times)
jorgepease
Active Member
Offline Offline
View Profile
« on: September 19, 2006, 02:08:36 PM »
I heard Mach3 was going to be able to interface with Galil products.
If so, is there an approximate time frame. I am trying to source
components. If we are talking 6 months away, I will go a different
route but if it's around the corner, I will work in this direction.
Jorge
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #1 on: September 20, 2006, 09:28:09 PM »
Good news Smiley we have started working on it and we hope to have it working in a few weeks...
After that I will be able to tell you more about how it works...
Brian
Fixing problems one post at a time Wink
www.newfangledsolutions.com
www.machsupport.com
jorgepease
Active Member
Offline Offline
View Profile
« Reply #2 on: September 20, 2006, 10:11:45 PM »
Sweet music to my ears.
I like their products, they explain things well, support is great
mach3 with Galil is going to be a powerful combo Grin
DennisCNC
Active Member
Offline Offline
View Profile
« Reply #3 on: October 12, 2006, 10:10:23 PM »
I have a DMC-2180 sitting around waiting Grin
It's gana be ethernet communication correct?
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #4 on: October 14, 2006, 06:58:34 PM »
Art is working on doing a 2120 and i am doing an 1880 (I think)
Smiley
So you can do both Smiley
www.machsupport.com
DennisCNC
Active Member
Offline Offline
View Profile
« Reply #5 on: October 15, 2006, 12:47:32 PM »
So mach will be like Cam$oft  -$  Shocked
Is it as complex making Mach work with Galil as it is with the G100?  Or is it more complex? the programming part on your side.
« Last Edit: October 15, 2006, 07:39:47 PM by DennisCNC » Logged
chad
Global Moderator
Offline Offline
When the going gets weird, the weird turn pro.
View Profile
« Reply #6 on: October 15, 2006, 01:32:55 PM »
So do those cards have step and Dir out or they only analog ?
Chad
DennisCNC
Active Member
Offline Offline
View Profile
« Reply #7 on: October 15, 2006, 07:38:40 PM »
Chad,
They have both and then some......
Brian,
If you need some one to test drive the software, I'll help with what I can.
« Last Edit: October 15, 2006, 07:48:35 PM by DennisCNC » Logged
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #8 on: November 09, 2006, 02:14:32 PM »
So I have run the Galil on the large mill under mach3 Smiley there are little problems but for the most part it is working very well! I Have it doing CV at about 400IPM on a mill that is 40,000 LB Smiley I have a video that I will send to Benny to convert to something that you all can read. WE have to get IO finished, homing, toolchanger and spindle. I would like to make it so that others can do there own toolchangers by making a new Toolchange plug in that you can just type the I/O in the order that it needs to happen... There will be more to come when I get to it Smiley
Brian
www.machsupport.com
chad
Global Moderator
Offline Offline
View Profile
« Reply #9 on: November 09, 2006, 05:47:47 PM »
Cool!  Glad to hear it is getting there.
Question, Say i wanted to do 5 axis kinematics, it that something the co-processor on the Galil handles or is that still mach math?
Chad
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 »   Go Up
Print
Jump to:
