Hello Guest it is June 13, 2026, 06:58:36 AM
Author Topic: PLease Help with code  (Read 9497 times)
« on: December 22, 2009, 08:59:34 AM »
This is the code on a button to zero machine co ordinates
What would be the code to set the dro to another dro
SetMachZero(2)
call SetDRO( 2, 0 )
So that dro 2 is the same as dro 20 as an example
I am sorry but i don't want to learn another app  ;D
melee
Re: PLease Help with code
« Reply #1 on: December 22, 2009, 10:32:34 AM »
Hi
You could do it this way
SetOEMDRO( 2, GetOEMDRO(20) )
(NB. SetDRO and GetDRO are deprecated from v2.6*********)
regards
Melee
« Reply #2 on: December 23, 2009, 12:03:41 AM »
Melee
Thanks for the reply, unfortunately it did not do what i wanted it too.
Phil
melee
« Reply #3 on: December 23, 2009, 03:39:12 AM »
Hi
You will need to be specific as to the exact code you used, where you put it and how it is activated.
SetOEMDRO( 800, GetOEMDRO(801) ) for instance, WILL set the X axis main DRO to the contents of the main Y axis DRO.
regards
Melee
« Reply #4 on: December 23, 2009, 04:29:08 AM »
Hi & thanks
I want to set X machine Co Ord OEM83 dro to X Ref POs Offset OEM33 Dro
I set it as to the format you said would work but it doesn't.
What i am trying to achieve with the press of a button is to set machine co ordinates (X=83) to that  axis offset dro (X=33)
melee
« Reply #5 on: December 23, 2009, 08:52:11 AM »
Ahhh I see,
Unfortunately I suspect you will be unable to set the Machine Axis Co-ordinates to anything, except 0 when referencing to Home.
The machine co-ordinates are absolute and physical.
If you could change them to another figure ( even an offset of themselves ), the controller would be unable to tell where the machine axes were and would happily crash at speed through the home positions.
I actually  tried changing the values through MachMad and whilst you can see it change, it is immediately returned to its original value.
regards
Melee
« Reply #6 on: December 23, 2009, 10:55:42 PM »
Melee,
Thanks for your help on this, but a bit of a shame really.
Any machine owners who do not use homing switches and hard limits, "and there seem to be lots", makes life is harder.
Phil
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #7 on: December 26, 2009, 05:09:26 AM »
If you look in Config..Homing/Limits you can specify a home offset for each axis there. You can not change it on the fly but if the offset is static it will work, I use it for my tool changer.
Graham
« Reply #8 on: January 01, 2010, 06:57:05 AM »
Thanks Graham
