February 13, 2012, 02:39:33 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Brains Development
| | |-+  Detecting Fwd and reverse of Axis
Pages: 1   Go Down
Print
Author Topic: Detecting Fwd and reverse of Axis  (Read 864 times)
codegrush
Active Member
Offline Offline
View Profile
« on: December 12, 2009, 12:32:26 AM »
Hi, I'm trying to detect when my A axis if moving forward or reverse. when moving forward it will actuate a solenoid valve and in reverse it will actuate a different valve and only when it is moving.
I'm new to brains but can someone help me with this? I don't see a dro for direction in the variable list.
  David P
spunk
Active Member
Offline Offline
View Profile
« Reply #1 on: December 18, 2009, 05:47:44 AM »
same here.
is there a way to actually use the status of the Cdir pin in brains?
would come in handy for me...
sunmix
Active Member
Offline Offline
View Profile
« Reply #2 on: January 07, 2010, 03:47:40 AM »
i did try using brains.
you can compare X AXIS DRO using brains.
Pages: 1   Go Up
Print
Jump to:
