February 13, 2012, 12:08:41 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Video P*r*o*b*i*n*g
| | |-+  g code from touch probe?
Pages: 1   Go Down
Print
Author Topic: g code from touch probe?  (Read 4533 times)
Tristar500
Active Member
Offline Offline
View Profile
« on: November 30, 2009, 05:04:52 PM »
It was suggested that I pose this question here on the video probing forum even though I'm using a touch probe..
Thanks!
I'm looking for a way to edit the code generated by the digitizing wizard (not plug-in) to a more usable format.  The file Mach generates is missing the x, y and z characters and simply separates the coordinates with a comma.
I could generate a point cloud in my cad program if the code was simply edited to include the X, Y and Z letters in each line..
Here's an example
Here's what I have to start with from Mach
-6.032136,1.419120,0.835333
-5.907102,1.419120,0.822000
-5.782069,1.419120,0.803333
-5.657035,1.419120,0.776000
This is what it needs to end up as so my cad/cam can read it.
X-6.032136,Y1.419120,Z0.835333
etc..
Any suggestions?
RonO
Active Member
Offline Offline
View Profile
« Reply #1 on: December 06, 2009, 09:39:08 AM »
You could use a word processor.
Replace all the "-" with "X-"
Replace all the ",1" with "Y1"
Replace all the ",0" with "Z0"
Of course this only works if the first number for Y is different than the first for Z.
Ron
spunk
Active Member
Offline Offline
View Profile
« Reply #2 on: December 07, 2009, 06:25:22 AM »
if you're any good with Excell you could write a macro to do this automatically... splitting it up after every comma...
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #3 on: December 14, 2009, 11:48:55 AM »
Al Lenz has written a brilliant little VB program to do just this. It is called XYZ Converter.exe and can be downloaded from this page.
http://www.machsupport.com/forum/index.php/topic,13301.msg87229.html#msg87229
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
JayC
Active Member
Offline Offline
View Profile
« Reply #4 on: January 03, 2010, 07:12:37 PM »
I can write a simple C program do do that, but how do you get if from a triplet to a usable mesh?
Update: I have written a Windows CPP app for this. Now what?
Update: nevermind, found MachCloud
« Last Edit: January 03, 2010, 11:04:22 PM by JayC » Logged
psutex
Active Member
Offline Offline
View Profile
« Reply #5 on: June 25, 2010, 11:13:36 AM »
I am not in front of my machine right now, but I think in one of the preferences or settings you can turn on/off having the coordinate letter or not.
Rick
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #6 on: June 25, 2010, 12:10:49 PM »
Rick is right......if this is what you need.
Ports and Pins / Mill Options
"I haven't failed. I've just found 10,000 ways that won't work."         Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
Pages: 1   Go Up
Print
Jump to:
