Hello Guest it is November 07, 2026, 12:17:04 PM
Author Topic: touch probe file converting to g gode??  (Read 15570 times)
« on: November 30, 2009, 04:03:31 PM »
I'm looking for a way to edit the code generated by the digitizing wizard (not plug-in) to a more usable format.  The file Mach generates is missing the x, y and z characters and simply separates the coordinates with a comma.
I could generate a point cloud in my cad program if the code was simply edited to include the X, Y and Z letters in each line..
Here's an example
Here's what I have to start with from Mach
-6.032136,1.419120,0.835333
-5.907102,1.419120,0.822000
-5.782069,1.419120,0.803333
-5.657035,1.419120,0.776000
This is what it needs to end up as so my cad/cam can read it.
X-6.032136,Y1.419120,Z0.835333
etc..
Any suggestions?
Offline alenz
  •  137 137
Re: touch probe file converting to g gode??
« Reply #1 on: December 01, 2009, 12:34:23 AM »
See if this works..
al
  •  9,375 9,375
« Reply #2 on: December 01, 2009, 04:19:52 AM »
Another excellent program Al.
« Reply #3 on: December 01, 2009, 07:46:18 AM »
if you go to the Config menu then Ports and Pins then Mill Options then digitizing you will see a box that if checked may put X Y and Z letters in for you
good luke for me is wrok very well
tulip
« Reply #4 on: January 19, 2011, 09:43:52 PM »
Hi Out their , Can anyone tell me how to retrieve the probe setup, in Mach3 !   I looked at the tutiral for Mach3 !
opened up ,operator , scroled down to ,VB Script Editor, clicked it and opened up folder in that window , could not find the PROBE listing like in the tutiral for Mach3!!  ?    ANY Help    THANKS
