Hello Guest it is June 09, 2026, 07:51:31 PM
Author Topic: Tickers  (Read 27008 times)
Tickers
« on: November 29, 2009, 06:34:54 AM »
Not sure if this is a machscreen problem or something else...
If I copy the standard 1024.set and then save it as something else, the tickers no longer work. For instance, on the main screen there is ticker0 next to the reset button which, on startup, displays "Press Reset .... Emergency Mode..." etc. In the saved screenset it just shows 'ticker0' all the time.
However, the 'Error', 'profile' and 'File' labels correctly show messages.
Re: Tickers
« Reply #1 on: November 30, 2009, 01:32:38 PM »
Hi dunkers
this is a MachScreen problem, I will fix it.
Klaus
The brain isn't a soap, it doesn't shrink when used.
Re: Tickers
« Reply #2 on: November 30, 2009, 03:00:17 PM »
Hi dunker,
the ticker issue is fixed in version V1.33.c. You can download it from my website.
Klaus
Re: Tickers
« Reply #3 on: November 30, 2009, 04:10:16 PM »
Thank you very much :)
