Welcome, Guest. Please login or register.
Did you miss your activation email?
May 25, 2012, 12:42:18 PM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Mach Discussion
| |-+  General Mach Discussion
| | |-+  DID YOU KNOW THIS
Pages: « 1 2 3 4   Go Down
Print
Author Topic: DID YOU KNOW THIS  (Read 14704 times)
ttm
Active Member
Offline Offline
Learning my first CNC router plasma setup
View Profile
« Reply #30 on: January 23, 2012, 05:35:15 AM »
What Keithmech said, plus:
     Get you a screen captur utility, like Gadwin Print screen,
I am iusing snagit, you can set up a capture for auto sccrolling, and when you switch to that active window, you drop your mouse in the window you want to capture and it will auto scroll the entire screen, it worked really well in mach setup screens, gaveme a nice pic of the entire ports and pins,  - now if i can just find a complete list of the pins for my setup
Logged
DDWALKER
Active Member
Offline Offline
View Profile
« Reply #31 on: April 30, 2012, 06:13:55 PM »
Hello Everyone
For users using an Xbox controller for their jog box.
Did you know that by clicking the control sticks you toggle from continuous jog to incremental jog. Now if I could change increments from the Xbox controller??
Maybe this is helpful.  Smiley
David
Logged
Pages: « 1 2 3 4   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.16 | SMF © 2011, Simple Machines Valid XHTML 1.0! Valid CSS!
