Home
Downloads
Mach and LazyCam
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Known Bugs
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
February 13, 2012, 03:38:36 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
FAQs
In need of a low speed spindle motor
Pages:
1
Go Down
« previous
next »
Author
Topic: In need of a low speed spindle motor (Read 1504 times)
avirostick
Active Member
Offline
on:
November 27, 2009, 12:20:26 PM »
I posted this question in the router building section and didn't get any replies, so I thought I'd try it here. My question is... Is there any spindle motors or palm routers for cnc router that aren't jacked up to 15,000 to 30,000 rpms? I got a Rotozip on mine, and it's good for everything not metal.
I just want to do some very light machining on steel, and don't want to burn up my bits. Getting a milling machine is out of the question right now. What I want to do is plunge a 1/16" carbide endmill about .040 into steel, and do it repetitively. I need about 3000 rpms, but even a spindle tool that would go down as low as 5000/7000 rpms I would be happy with. I am unfamiliar with the 240v stuff, and I only have 110/120V electric. As of now, at 15,000 rpms and keeping the feed low, it's just not working. Thanks for your help.
MikeHenry
Active Member
Offline
Re: In need of a low speed spindle motor
Reply #1 on:
November 28, 2009, 04:07:52 PM »
Hw about a Sherline motor? I'm pretty sure that they sell them as spare parts.
Mike
Global Moderator
Offline
Reply #2 on:
November 28, 2009, 06:29:25 PM »
Don't they sell a foot pedal or vari-stat or something so you can slow the Rotozip down?
avirostick
Active Member
Offline
Reply #3 on:
November 28, 2009, 08:20:10 PM »
I'll definitely look into that Rich. Don't know much about Sherline, but will look into it Mike. Thanks much, I always get the best help from the guys on this forum.
avirostick
Active Member
Offline
Reply #4 on:
November 28, 2009, 11:19:08 PM »
Just did some research. I believe what I'm looking for is called a rheostat. They sell on Ebay for about $18.00 bucks and work for ac/dc motors. If this works out, I'll be thrilled. Thanks again.
Sam
THIS SPACE FOR RENT.
Global Moderator
Offline
Reply #5 on:
November 29, 2009, 11:35:54 AM »
I can give you some "been there, done that" advise on using a rheostat. You will loose a considerable amount of power when slowing the motor down. Plunging a .125 endmill down 0.04 might not be any problem, but doing anything that taxed the motor at full speed, would be futile at a slow speed. Start the motor at full speed, then ramp down the speed. Don't try to start it slow, unless you want to blow fuses or fry the windings in the motor. Good luck.
"I sometimes think we consider the good fortune of the early bird and overlook the bad fortune of the early worm." FDR - 1922
Global Moderator
Offline
Reply #6 on:
November 29, 2009, 01:54:45 PM »
Thanks Sam,
Let me add this. I think they call them vari-stats. They are used for hot plates. Don't use them for slowing down an AC motor ( drops voltage and amperage goes up and can fry a motor). Never use one instead of a transformer to lower the ac for converting to DC ( you can get electricuted because of the grounding).
Picengraver
Active Member
Offline
Reply #7 on:
December 27, 2009, 05:08:10 PM »
Have you considered using a vari-speed drill motor? I have a motor from an 18VDC drill that I plan to adapt to my router (when I get a round tuit
John Champlain
www.picengrave.com
avirostick
Active Member
Offline
Reply #8 on:
February 28, 2010, 08:34:09 PM »
I bought the rheostat for 18 bucks and milled .080 nickel silver using a 1/16 carbide ballnose. I cut up a 2x6" sheet of material into 40 little pieces. I think the deepest I could mill at once was .030, but hey, at least I milled it. Not bad for a 15,000 to 30,000 rpm mini router.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP motion controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Loading...
