Hello Guest it is June 10, 2026, 04:46:59 PM
Author Topic: Driver Problem  (Read 11295 times)
Driver Problem
« on: November 25, 2009, 03:55:47 AM »
Hello,
I'm running a a win2000 machine with a 200 Mhz processor and 128 Mb's of memory.
I encounter a problem during the installation of Mach3, the Driver for the Parallel port won't install.
The 'No driver sensed, run Driver test' is displayed, but when I try to do that without having Mach3 running it gives me the same message when I double click the
Driver Test.exe.
Do any of you know in which way I can solve this problem?
With Kind Regards,
Daan de Vos
Re: Driver Problem
« Reply #1 on: November 25, 2009, 04:04:59 AM »
The minumum specs for Mach3 are 1GHz processor and 512MHz ram so think you need to get a better computer I am afraid.
Re: Driver Problem
« Reply #2 on: November 25, 2009, 04:20:14 AM »
I knew about the minimal specifications, but I don't have anything else to work with.
The only thing I have to do, is to get the jogging working so I can test if the axis move.
Can you think of something else that could be my problem?
With kind regards,
Daan de Vos
Re: Driver Problem
« Reply #3 on: November 25, 2009, 04:23:35 AM »
You can try the special driver but as your computer is so far below specs you are going to have issues in the future even if that works.
Re: Driver Problem
« Reply #4 on: November 25, 2009, 04:24:35 AM »
Mach2 might be a better choice for you but even with thyat I think your computer is a bit low spec'd
Re: Driver Problem
« Reply #5 on: November 25, 2009, 04:26:54 AM »
Isn't there another way to install or test the driver?
Re: Driver Problem
« Reply #6 on: November 25, 2009, 04:28:25 AM »
Try the special driver, it is in the Mach3 folder, just double click on it. If that doesnt work then there is no choice but try Mach2 or get a better computer.
