Hello Guest it is June 12, 2026, 03:24:25 PM
Author Topic: Please help, I can not use system hotkeys when design a new screen  (Read 26178 times)
Dear all,
I use Mach3screen to design a new screen set, but I can not use any system hotkeys to move one axis
when I assign "right arrow key " to increase X
                      "left arrow key" to decrease X
When I load my own .set, I cannot use those hot key, when I press "right arrow" or "left arrow", X value does not change.
 But if I load 1024.set or plasma.set (default in Mach3 folder) every thing is OK.
(I also add a button to enable or disable Jog mode, and a reset button.)
Sorry because my English is not good.
I attache my test.set
and my nrw.xml
please help me.
« Last Edit: November 24, 2009, 10:26:42 PM by student09 »
Re: Please help, I can not use system hotkeys when design a new screen
« Reply #1 on: November 25, 2009, 02:18:55 AM »
Hello,
are you using Mach3Screen or MachScreen? If you are using MachScreen, put your controls in a page number  > 0.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: November 26, 2009, 03:28:54 AM »
Thank you, I tried it succeed.
