Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 25, 2012, 11:36:58 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
FAQs
Stepping too fast / Motor tuning wrong
Pages:
1
Go Down
« previous
next »
Author
Topic: Stepping too fast / Motor tuning wrong (Read 1024 times)
gewe
Holding
Offline
on:
November 18, 2009, 03:48:21 AM »
Hi there..
I've just updated from version 3.042.020 to 3.042.32. But now my machine runs 20-30%faster than before which could cause mechanical step loss...
I have already retuned my motor settings. But when I set maximum step velocity to 3000 steps it runs approx. 3900 Steps.
2000 results in 2600.
With the old versions the motor tuning settings were OK.
This happens when jogging around. Also setting speed with the F command results in faster step rates while executing programs...
What is going wrong?
regards
gewe
Davor
Active Member
Offline
Re: Stepping too fast / Motor tuning wrong
Reply #1 on:
November 27, 2009, 06:23:35 AM »
It's working the same here.
And I have pulsing speed set at 35kHz. In diagnostics shows me it pulses at 49.5kHz.
Same for 25kHz setting it pulses 35kHz, for 45kHz setting it pulses at 65kHz.
Speeds are faster for this ratio in Jog and Feedrate.
Tried DriverTest it passes OK.
Also tried NormalDriver.bat and SpecialDriver.bat with same effect.
Tried to reinstall and still too fast.
Please Experts help me.
Global Moderator
Offline
Reply #2 on:
November 27, 2009, 09:45:10 AM »
You set the steps per based on calculated values. There is a write up in Members Docs on how to calculate the step per unit. So make sure you have that correct before tuning.
Velocity determines how fast your axis will move and accel is is the time to go from rest to velocity / reverse is true for deccelerating.
Make sure you click "save axis settings" after changing any settings.
There is nothing to be gained by setting the pulse rate higher than what is required,so if 25k is adequate for your steps per unit there is no need to go higher.
I have not seen what you are describing if your steps per unit are correct.
Last Edit: November 27, 2009, 09:50:37 AM by RICH
Davor
Active Member
Offline
Reply #3 on:
November 28, 2009, 09:34:23 AM »
Hi Rich,
Motor tuning was done OK, it works correct.
It's just that in Mach for F7000 it moved 10500 in units/min and machine moved at 10500 too.
It was pulsing 35kHz at setted 25kHz in ports and pins section.
I reduced CPU speed on computer from 3Ghz to 2Ghz. Now it's pulsing 25kHz at setted 25kHz.
Davor
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
