May 25, 2012, 10:30:53 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach SDK plugin questions and answers.
| | |-+  Pluging and Macro interaction?
Pages: « 1 2   Go Down
Print
Author Topic: Pluging and Macro interaction?  (Read 1350 times)
Steffen_Engel
Active Member
Offline Offline
Chattanooga, TN, USA
View Profile
« Reply #10 on: December 23, 2009, 10:54:15 PM »
I think, VBA in a Plugin is not possible.
But the access to all of the Mach3-Functions you have in VBA you have in the plugin too. The only thing it is in C, not VBA.
eg
in VBA:
Code:
Call SetOEMDRO (818, GetOEMDRO (818) * 1.1)
in C in aPlugin:
scripter.SetOEMDRO(818, scripter.GetOEMDRO (818) * 1.1);
VB should be possible, but not VBA I think.
In both cases you have to compile those scripts or you have to build your own interpreter.
That's all, not more, not less.
Bye, Steffen
mjtooba
Active Member
Offline Offline
View Profile
« Reply #11 on: December 24, 2009, 04:29:43 PM »
thanks steffen
script engine is in heart of mach and not accessible from plugins...   Cool but VBA core function are available to C, i could use python or java script, but it doesn't worth it.
Pages: « 1 2   Go Up
Print
Jump to:
