Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 25, 2012, 10:22:02 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
General CNC Chat
Show"N"Tell ( Your Machines)
gears, ballscrews, and setscrews
Pages:
1
Go Down
« previous
next »
Author
Topic: gears, ballscrews, and setscrews (Read 853 times)
BarryB
Active Member
Offline
on:
October 23, 2009, 01:50:52 AM »
Hi folks, I've been a modeling madman getting all my parts in the modeling app so I can get some precise connecting plates fabricated. IN the process, I was assembling lots of parts together, like ballscrews, end supports, gearing...
This is where I noticed that the gears lock in place using a set screw, only the ballscrews are machined smooth. There's no flat side for the set screw to lock onto. Is this customary, we just screw directly onto the round shaft? Do we drill a detent for the screw? Do we file down a side?
Forgive my ignorance n this matter, it's not something I do everyday;)
Barry
SteinarN
Active Member
Offline
Re: gears, ballscrews, and setscrews
Reply #1 on:
October 23, 2009, 03:09:31 AM »
If you don't do anything then it will be hard to get the gear off because of the burrs made by the set screw when you tighten it. I would have drilled a shallow recession in the shaft with a drill bit somewhat larger than the diameter of the set screw. Don't drill it deep! Only so deep that the diameter of the recession becomes slightly larger than the set screw. Then it should not be any problem removing the gear later. If the gear doesn't fit tight on the shaft I would have used locktite on the shaft also.
Last Edit: October 23, 2009, 03:11:04 AM by SteinarN
Tweakie.CNC
Active Member
Offline
Super Kitty.
Reply #2 on:
October 23, 2009, 08:28:41 AM »
My ballscrews were a lot harder than my drills so I ground a small flat on the machined portion of the ballscrews.
Hope this helps.
Success consists of going from failure to failure without loss of enthusiasm. Winston Churchill.
Dan13
Active Member
Offline
Reply #3 on:
October 23, 2009, 09:51:23 AM »
On my machines the timing pulleys are screwed onto the ballscrew end, and are locked with a counter nut (or counter bolt in my case), and Loctite is applied to the whole assembly.
Daniel
BarryB
Active Member
Offline
Reply #4 on:
October 23, 2009, 10:24:52 AM »
Thanks for the tips. I think the first thing to do is machine some flats as some have suggested. I'll see if I can do that this weekend.
Barry
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
