Hello Guest it is June 11, 2026, 10:17:30 AM
Author Topic: SS on Laptop  (Read 12795 times)
SS on Laptop
« on: October 22, 2009, 12:03:54 PM »
Will SS work ok on a lap top with no parallel port and integrated graphics?
And do you still run the Mach 3 parallel port driver?
"Gravity, its not just a good idea its the law"
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: SS on Laptop
« Reply #1 on: October 22, 2009, 04:07:33 PM »
The only laptop that I have heard of not playing well with mach and the SS was a Toshiba Satellite. I would say about 1/2 the folks I have sold SmoothStepper to are using laptops. Also, you do not need to load the parallel port driver when using the SS. Just install the SS driver and plug-in after installing Mach.
Hope that helps,
Happy machining , Jeff Birt
Re: SS on Laptop
« Reply #2 on: October 23, 2009, 08:57:01 AM »
Hope that helps,
Yes it does. Thanks
