February 13, 2012, 01:44:10 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Screen designer tips and tutorials
| | | |-+  height of title and menu bars?
Pages: 1   Go Down
Print
Author Topic: height of title and menu bars?  (Read 1005 times)
mvcalypso
V4 Screen Contributor
Offline Offline
View Profile
« on: October 14, 2009, 04:11:39 PM »
Does anyone happen to know the height in pixels of the windows titleand menu bars?
I'm wondering what height is left over for screen real estate after these are accounted for.
Greolt
Global Moderator
Offline Offline
View Profile
« Reply #1 on: October 14, 2009, 05:13:30 PM »
Can't give you a definitive answer.
But I make my screens 700 pixels high to fit a 1024 x 768 screen.
You can rely on the "Auto Screen Enlarge" in Mach but I prefer not to use it.
Greg
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #2 on: October 14, 2009, 05:58:33 PM »
I make my graphics 1280x1024 in Photoshop, and use them in a 1024x768 screenset in Screen4.
Greolt
Global Moderator
Offline Offline
View Profile
« Reply #3 on: October 14, 2009, 08:33:18 PM »
All the standard Mach3 screens, and as far as I know, all the wizards (except for the latest one Ron did) are set out in such a way as to leave the bottom of the screen empty; leaving space for the standard windows task bar.
I think this is a good principal to follow especially if doing screens for others to use.
Again IMO there are valid reasons to shy away from auto screen enlarge. I don't expect others to share that opinion.   Grin
Greg
mvcalypso
Offline Offline
View Profile
« Reply #4 on: October 14, 2009, 10:17:17 PM »
Thanks guys,
upon further reflection, I've realized my question may have been simplistic -
programs can alter the size of the bars pragmatically and I believe users can also by fiddling with display themes etc....
I think I'll simply assume mach uses the default size bars and go from there (not sure how much that is yet, but I'll figure out some way to measure it).
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #5 on: October 15, 2009, 08:07:23 AM »
Just print screen and check in Photoshop or a similar app.
I use Auto Screen Enlarge without problems, btw.
mvcalypso
Offline Offline
View Profile
« Reply #6 on: October 15, 2009, 09:14:57 PM »
In case anyone should wonder...
On a 1024x768 screen, with mach at full screen, once you deduct the title and menu bars and the borders, I believe the area left for screen pages is 1016 x 719 pixels.   ...that also happens to be the size the mach blue screens use for background images also (so I guess those guy already figured out this bit of trivia).
Curiously the mach standard 1024 screen set is 967x725 - I find that test screens at 725 high cut off the bottom few pixels when displayed in mach.
So, I'm going with 1016x719 as the magic size and will let "auto enlarge" handle physical screens other than 1024x768.
Pages: 1   Go Up
Print
Jump to:
